Just a quick question can the 1500.1 output more than 1680 @ 1 ohm? I think somewhere I read that the 1680 @ 1 ohm is at 13.8 volts or something. I'm going to run 2 of the 1500's on a stock electrical with the "The Big 3" and 2 extra batteries in the rear. Subs are two 15" ZVX's, The amps are going to be run at 1 ohm. I should be fine right?
Skar Audio SDR 10" x2 (Sealed Box)
Skar Audio 1500.1D (1 Ohm) x1
Skar Audio TX525c (Front with dash tweeter) x1
Kenwood Excelon KFC-X173 (Rear Coax) x1
JL Audio 360.4 (Mids & Highs Amp) x1
DEH80-PRS
XS Power d3400
Singer Alternator 275A
98 Jeep TJ 4.0 5 Speed
Skar does the birth sheet thing? I never knew. That's pretty awesome.
DEH80-PRS
XS Power d3400
Are you running the 1500s separate or strapped? I don't recall a birth sheet in my amp box, but too I only have the 85.4 right now. Either way I think you'll be fine. They run well on the 1200D. Let alone a 2500 at .5 ohm lol
DEH80-PRS
XS Power d3400
should since theyre a high end company like rockford
edit i might be wrong
Skar is no where near Rockford, a lot closer to rockwood amplifiers then they are to rockford amps.
EDIT: to Big-A, I am exaggerating, but you shouldn't compare a amp like that to skar, especially not if you include customer service and reliability.
Edited by kirill007
Can I still fuse this amp with a 250A fuse? I am using CCA 1/0 and I am getting a 250A alternator. Or should I go lower in fuse size?
DEH80-PRS
XS Power d3400
Yes, you fuse for the wire. If the wire capacity is 250A.
I think your over exaggerating a little bit. They may not be top of the game but they are definitely not rockwood
2004 Dodge Ram
Head unit- Alpine iDA-x305s
Sound processor- Clarion eqs746
Mids/Highs amp- Alpine MRV-F345
Sub Amp- Alpine MRD-M1005
Dash Speakers- (3) Dayton Audio rs75
Front Door- Skar SPX65c
Rear fill- Skar SPX tweters and Dayton ND140 midbass
Sub- Fi Audio SSD 15 high QTS
SHCA power/ground cables and Stinger interconnect
XS power D6500 under the hood and D680 in the amp rack
Big 3+ with SHCA
http://www.stevemeadedesigns.com/board/topic/161174-dodge-ram-quad-cab-fi-ssd15-skar-audio-alpine-shca/?p=2326251
depends on the amp youll know how much itll put out when you get the birthsheet
Birth sheets are also pretty pointless. Most are done with a solid power supply and non reactive load.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
  • Who's Online   0 Members, 0 Anonymous, 1468 Guests (See full list)
