opinions?? on cut through and box design
hod913
I have a new body silverado and im doing a cut through next week. Problem is that I can decide to do 2 or 4 12's. I beleive the woofers i want to use need about 1.75 to 2.25 vent each so i would be on the border of specs.
I do NOT want to use the whole bed and I have take the measurements and should have around 8 cube before woofers and vent.
Do you guys think that would be enough air sapce for 4 or should I shrink it a bit and make it a box for 2?
Make round cuts to your cab and bed ... Not 90 degree cuts
The Accordion boot will fit and work much better with rounded cuts in your corners .... Also, it would be nice if you can have a full bed cover to protect your investment ....
x2 about the round cuts vs the square cut for the accordion boot for sure.. and tuned in for this too would like to see what other's say about it and such..
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
I know ... My blow thru has 4 10s Isoberic, but my goals were different.
If I was looking for goals like yours, I would go with no less than 4 12s ... Just saying
4 12s all day...
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
i just dont want to be short on air space and miss that deep drop trying to tune around 33-34 hrtz and get into the upper 20's with the hertz swing.
i listen to all types of music but love that deep drop that shakes everything. lol
Yea if your going as far as cutting a hole in your truck cab for bass then I wouldn't do anything less than 4 12's. DO IT right the first time so you don't waste time/money doing it a second time.
Edit- "DO IT" not donut lolol
4-12"s
Rock the 4th order, skimp a little on the sealed side for the woofers but try to maintain a 2:1 or 3:1 ratio.. Should get dirty..
2006 Silverado Ext. Cab
6-15" SSA ZCONS
4th Order Blow-Through
Pioneer AVH-P4200dvd
American Bass VFL 1100.1 12 volt
6 C&D Batteries
2-350A Singer Alternators and Stock Alt
DC Power Triple Alt Kit
MLA Module
3 Runs of 1/0
2 Sets of Boston Acoustics 6.5 Pro Components
Boston Acoustics 2-channel
Lots of Sound Deadener
....Build still in Progress...
  • Who's Online   0 Members, 0 Anonymous, 547 Guests (See full list)
