Fuses & multiple runs of 0 gauge.
I have a dc 3.5k, want to get full power from it.
If I do 2 runs of 0 gauge, would I use 4 400 amp fuses, or 2 200 amp fuses per run? It'd be going from front batt to back batt, then to my amp.
New Setup;
H/U; Pioneer DEH-80prs.
Wiring; 2 runs of 2/0 OFC & Big 3.
Subs; 2 D1 DC Level 4s.
Monoblock; DC 3.5k.
4 Channel; JBL GTO1004.
Highs; Vifa NE25VTS-04.
Mids; Aura NS6-255-8A.
Alt; 160a.
Batts; Optima, KHC1800.
from batt to batt you should fuse both front and rear at the wires rating. Capacity will also depend on wire length. For 1/0 OFC 300a is appropriate. For CCA 250a is appropriate. Fuse each positive run 2wice - once near the front batt and once near the rear batt.
for fusing to the amp some will say to just fuse to the wire as well, to be "safe" fuse to the amps rating or below - combined - meaning if you want 400a of power run a 200a fuse in each run if using 2 runs to the amp.
There is a lot of info on the site around this topic and I suggest some searching and reading (using the site search feature) to learn more so you understand what why and how vs just being told what to do. This way you can make your own decisions and undertsand the risks of fusing too high
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
as said^ but not all
the first fuse needs to as close to batt as possible (with in 18") and has a max rating no higher then the cable rating (the fuse is there to protect the wire and nothing else )
if that wire is going to another battery then after that battery there needs to be another fuse fitted as close to batt as possible (with in 18") and has a max rating no higher then the cable rating
then if you witch to project the amp you are fitting and if it doesnt have any built in fuses, you can add them in but they need to be fitted between the supply and item being projected
to save on fuses if the item you wish to protect requires it then a fuse rated @ required amp + an allowance for cable length and efficiency can be fitted down the line in replace of another as long as it doesnt exceed the wire rating
So you do have to fuse two times from front battery to the rear battery? I think that 2 fuses from front batt to rear batt is a bit much. If the first fuse goes then the second fuse wont to anything I think.
Skar Audio SDR 10" x2 (Sealed Box)
Skar Audio 1500.1D (1 Ohm) x1
Skar Audio TX525c (Front with dash tweeter) x1
Kenwood Excelon KFC-X173 (Rear Coax) x1
JL Audio 360.4 (Mids & Highs Amp) x1
DEH80-PRS
XS Power d3400
Singer Alternator 275A
98 Jeep TJ 4.0 5 Speed
and when possible ... make sure that your grounds are as short as possible to the body of your vehicle (frame would be best)
at each battery negative terminal application ... Amplifier Negative terminal applications too
A fuse within 18 inches of each battery positive terminal application in the vehicle ...
Would that not mean to fuse every positive wire from every rear battery? I just think that from front battery to rear bank to fuse twice in 1 wire is strange. Once the first fuse at the front battery goes then the wire has no more power coming from the alternator. Unless the fuse in the second wire did not go. But if both fuse's go next to the front battery in the 2 or however many wires there are then the point of the rear second fuse in the wires are pointless.
DEH80-PRS
XS Power d3400
If you have 2 batteries within 18 inches from each other, one fuse within 18 inches of the battery terminal lead going to the front of the vehicle will be fine ... Your fuses are there not for the batteries sake, but for your system's safety. Especially when you run wire through metal and something goes wrong, you are protected from front and rear battery sources ...
  • Who's Online   1 Member, 0 Anonymous, 1169 Guests (See full list)
