MrClean636 Posted March 12, 2013 Report Posted March 12, 2013 Bought a new car, re-doing the system, need some advice. I want to do a new setup with 4, 10" subs. now I'm not entirely sure the brand of sub yet, I'm still at the drawing board. But I do know I want to stay above 3k rms, but I don't want a huge electrical draw... Dilemma... I still have my DC 5.0K from my last setup with two, XLm2 15's. I was thinking I could still use that amp, but keep the gain down, as it should be more efficient than say a 3.5K amp, pushing full output. Right? Or am I just thinking crazy? Can I get just 3.5 ish out of my 5K?? Concerns... 1. 5.0K can draw way more than 3.5K... is efficiency better here?? 2. Biggest alternator I have been quoted by anyone, was from Mechman and it was a 270 amp unit. 3. I don't want 2, 73 pound batteries in the trunk like I did in my last car. I do plan on upgrading my alternator to the 270 amp unit, doing an upgraded starting battery, and two runs of 1/0 knu konecpts wire from the front to back. I just don't want all the battery weight in the back, but still looking to get loud.. Thanks for the help! Hopefully I'm not ranting hahaha! Car: 2011 Ford Taurus SEL / Alt: DC Power 270XP (Will be here 7/17!!!) Deck: Pioneer AVIC-Z140BH / Amps: (1) DC 5.0k, (1) RF T400-2 Speaks: RF T2652-S 6.5" and RF T1692 6x9" Subs: (2) DC XLm2 15's / Batts: (2) XS XP3000's Wiring: Kolossus Fleks Kable 1/0 (2 runs)
Watch the bass Posted March 12, 2013 Report Posted March 12, 2013 Than do not more than the 3.5 K, maby your 5 K amp run´s on 2 Ohm in this range! "in the abundance of water, the fool is thirsty" Bob Marley
mrd6 Posted March 12, 2013 Report Posted March 12, 2013 Sounds like you've got it all figured out! What you are planning should work just fine if you set your gains accordingly My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
Emmet Posted March 12, 2013 Report Posted March 12, 2013 Than do not more than the 3.5 K, maby your 5 K amp run´s on 2 Ohm in this range! The 5k is rated at 2.3k at 2. i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah.. You want this to happen to you? Give decent handshakes people. I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
Chris Hammer Posted March 12, 2013 Report Posted March 12, 2013 I would just set everything with a DD1 like you normally would..then leaving everything where it is...back the gain off and use a clamp meter to get 3.5k.... My guess is the 5k would be more efficient making 3.5 but thats just a guess. MY BUILD *****http://tinyurl.com/gmcbuild***** Vehicles 2005 GMC Canyon CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.) crf250r - Used to be race bike..now I just trail ride..practice at the track on it. CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg Sold to: Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585 Shower farts still piss me off.I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
Watch the bass Posted March 12, 2013 Report Posted March 12, 2013 Than do not more than the 3.5 K, maby your 5 K amp run´s on 2 Ohm in this range! The 5k is rated at 2.3k at 2. Strange 2.3 on 2 and 5 on 1, would be intresting to see a 2 Ohm clamptest. I would stay with the 5 K do 4 SA 10 or something like this than you are fine and saver with your electrical. You will loose a vew $ if you sell the 5 K and buying than the 3.5 K. "in the abundance of water, the fool is thirsty" Bob Marley
Tarball Posted March 12, 2013 Report Posted March 12, 2013 IMO even with a 270 you are goign to need some batteries in there... CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
mrd6 Posted March 12, 2013 Report Posted March 12, 2013 Eh, a good battery under the hood and a brain behind the volume control is all you should really need if you aren't trying to demo full tilt all the time. Of course more batts wouldn't hurt though My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
Hunters21w Posted March 13, 2013 Report Posted March 13, 2013 Just keep the gain down so that your voltage drop isn't too bad. The more batts you get, the higher you can turn it up toward your max clean setting. 06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
MrClean636 Posted March 13, 2013 Author Report Posted March 13, 2013 I would just set everything with a DD1 like you normally would..then leaving everything where it is...back the gain off and use a clamp meter to get 3.5k.... My guess is the 5k would be more efficient making 3.5 but thats just a guess. That's similar to what I was thinking. Just will need to get my hands on a clamp meter once everything starts rolling along! Thanks! Than do not more than the 3.5 K, maby your 5 K amp run´s on 2 Ohm in this range! The 5k is rated at 2.3k at 2. Strange 2.3 on 2 and 5 on 1, would be intresting to see a 2 Ohm clamptest. I would stay with the 5 K do 4 SA 10 or something like this than you are fine and saver with your electrical. You will loose a vew $ if you sell the 5 K and buying than the 3.5 K. That's actually one of the exact setups I was thinking of! I was looking at the SA 10's as a possible option, or even doing DC again and going with the lvl 2 or 3. Just have to determine that yet... And my thoughts exactly, I'd honestly at most probably make $50-$100 back to get a 3.5k which will limit me if I do eventually want to upgrade again. IMO even with a 270 you are goign to need some batteries in there... Yeah I plan on still having a battery. Was thinking maybe a single XP3000, or numerous smaller power cells. Only problem there is voltage drop... Car: 2011 Ford Taurus SEL / Alt: DC Power 270XP (Will be here 7/17!!!) Deck: Pioneer AVIC-Z140BH / Amps: (1) DC 5.0k, (1) RF T400-2 Speaks: RF T2652-S 6.5" and RF T1692 6x9" Subs: (2) DC XLm2 15's / Batts: (2) XS XP3000's Wiring: Kolossus Fleks Kable 1/0 (2 runs)
