2 10s or 3 8s
Jbiddle530
alright so heres the question i have a box 2.5 cubes net volume built for where it is fitting in my car custom fit and everything.. tuned to 32 hz with 2 3" flared aero ports. the box is just about done accept for the sub baffle. my question is since my box would work perfect with 2 10s or 3 8s its a good amount of air space for either i am torn between the two. what would you guys choose.. say the woofer model and brand is the same. say kicker l7's for instance on a zx1500 not what i have but just wondering what would be your choice 3 8 l7s on a 1500 or two 10 l7s on a 1500???
as of right now though i have 1 treo tsx 10 dual 4 i am wondering if i should try to find another or if i should get 3 8s of some sort..
the amp is a kicker kx850.2 so there would be one sub to each channel getting 425 rms or more each.... if i was to run the 3 8s id cut a oval in the center divider and make it into a common chamber with a brace and still need to put the other aero port in.. going behind the seat of a 300zx..480675_347734042013821_815188688_n.jpg
I would go with the tens because its less work...
"The secret to creativity is knowing how to hide your sources." Albert Einstein
4 8's!!!
REP
4x 8
2 up
2 back/front
and how would you wire 3 to a 2ch amp, you can
if not 4x 8" then def have to 2x10
the kx is a good old amp, i had a kz300.4 for over 7years on my daily and it done the job nicely
Better give your box dimensions, Im sure that does not account for port displacement. Anyways I would build around the subs I want, the MDF is inexpensive, going for 4 sa8 would be very expensive and would need 2K power at least.
4 sa8 on 850rms would still hit hard, im running 2 on 400 and there no noticeable difference to the ear between that and 750 on 2, except the shame on peoples faces when the see only 2 8 on 400
and anyways he never say sa8 (L7 8 was mentioned)
personal spend the $25-50 on some mdf
get 4 e8v2 d2
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
