CommonSyns Posted March 19, 2013 Report Share Posted March 19, 2013 My head unit just randomly shuts off and it takes awhile for it to turn back on. I just re-soldered all connections from the HU harness to the vehicle harness like 2 days ago. But I had this problem before it was soldered also. It will also say sometimes "ATT" with a speaker icon, It will do this at random also. EDIT: The internal amp is off also on the head unit. Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed Link to comment Share on other sites More sharing options...
CommonSyns Posted March 30, 2013 Author Report Share Posted March 30, 2013 i think the problem might be over heating, whenever i turn the heat on the deck shuts off and stays off for however long it takes. my local car audio store back when i was still in CT told me that it might be a voltage issue and that i needed to change out the 3 main wires (battery, Ground, power) with a heavier gauge wire, something called voltage protect. Is this true? Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed Link to comment Share on other sites More sharing options...
KMS Posted March 30, 2013 Report Share Posted March 30, 2013 What subs and amps are you running and what gauge wire is being used? I doubt it has anything to do with your headunit cutting out though. When you're playing the music you should see the voltage on the display IIRC, at what voltage does it turn off? Alpine PDX-V9 Morel Tempo 6 Alpine SBR-S8-4 Alpine CDE 149BT Link to comment Share on other sites More sharing options...
REVOofRustler Posted March 30, 2013 Report Share Posted March 30, 2013 Try running a new ground for it (preferably where you have the amps grounded) along with a new constant 12v run (straight from battery). Make sure to fuse the consant run as well. 2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant - Fi and Crescendo - Stock Bose System - http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota 136.4 Sealed @ 29hz 137.0 Drivers window open @ 26hz Link to comment Share on other sites More sharing options...
CommonSyns Posted March 30, 2013 Author Report Share Posted March 30, 2013 subs and amps are skar zvx 15's two of them and 2 of the skar 1500.1ds. 1/0 running to the sub amps the 1500.1ds and 1 run of 0 gauge running to a 1/0 in to a 4 out fuse holder running to my mids & highs amp a JL 360.4. each amp has its own battery. a ground wire running from the head unit to where the amps are grounded? isnt that a ling run of negitive wire? will i get noise? i'll try it. Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed Link to comment Share on other sites More sharing options...
REVOofRustler Posted March 30, 2013 Report Share Posted March 30, 2013 What do you have as far as electrical goes? 3000+ watts on stock electrical is really pushing it... 2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant - Fi and Crescendo - Stock Bose System - http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota 136.4 Sealed @ 29hz 137.0 Drivers window open @ 26hz Link to comment Share on other sites More sharing options...
CommonSyns Posted March 30, 2013 Author Report Share Posted March 30, 2013 stock alt, soon to be ho 250 singer alt, no big three yet, the big three wont fit on my battery terminals, and the terminals are brand new also. wven at full tilt i charge at 13.7 only when i bump some really bassy songs will i go down to 12.7 - 13.3 but most of the time im at 13.7 idle and on the high way, but when on the high way i bearly lose any voltage. the lowest idle its droped to on full tild was 12.1-12.4 thats on decaf and not rap, on rap i go down to 12.7 Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed Link to comment Share on other sites More sharing options...
michigancapri92 Posted March 30, 2013 Report Share Posted March 30, 2013 sounds like HU voltage problems causing it to over heat ... The 80 PRS has a function that you can turn the internal amps off, mine ran a little warm and i found that function so i turned the internal amp off and it did better. (dont know if you are using the internal amp or not or knew if you could turn off) Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED Link to comment Share on other sites More sharing options...
alaskanzx5 Posted March 30, 2013 Report Share Posted March 30, 2013 try calling pioneer electronics? im sure they could answer question about this. more solid wiring couldt hurt. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
CommonSyns Posted March 31, 2013 Author Report Share Posted March 31, 2013 the internal amp is shut off, but resets itself to back on when the deck shuts off and back on, i'll try to call pioneer on monday. Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed Link to comment Share on other sites More sharing options...
