Mobileaudio25 Posted March 20, 2013 Report Posted March 20, 2013 I don't wanna turn my hu all the way up with my small 3.5 kickers running off the hu when I use the dd1. If I fade to the rear so the speakers don't receive any power it won't effect anything with the dd1 will it?
zxsonnyxz Posted March 20, 2013 Report Posted March 20, 2013 You will never be able to reach the output voltage from the HU that you used to set your gains. You need to set your amp(s) according to the signal strength of the HU at the maximum point where nothing has started to distort yet, with the way you have it set up. Wheither it be the 3.5"s, the internal amplifier. or the signal output. STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback!
Noel989 Posted March 20, 2013 Report Posted March 20, 2013 I would disconnect them or do it really fast Or you can Find up to what volume they can take and set your gains to that volume Cause theirs no point of finding the max cause once you go over the limits of the 3.5 they'll start sounding like shit Build Log - http://www.stevemead...-cruiser-el-pt/
zxsonnyxz Posted March 20, 2013 Report Posted March 20, 2013 STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback!
Mobileaudio25 Posted March 20, 2013 Author Report Posted March 20, 2013 Once I get everything done with the DD ill adjust the bands and they are fine. Those 3.5s just don't like a lot off bass at all...
Mobileaudio25 Posted March 20, 2013 Author Report Posted March 20, 2013 I'm only running one set of speakers off of the head unit. I know that my head unit does not distort at all. So are you suggesting that I set my amplifiers to their max gain before clipping at the point that my 3.5s begin to distort on the head unit and set my amps gains according to that volume number?
Mobileaudio25 Posted March 20, 2013 Author Report Posted March 20, 2013 Never mind, my question was already answered! Thanks guys!
bcbrassard Posted March 20, 2013 Report Posted March 20, 2013 Junk the 3.5" and get something better to DD-1 the amps with to maximize your system. Should set your system to the weakest speaker at the risk of degrading the whole system. just my opinion, seems like something is backwards here.
Mobileaudio25 Posted March 20, 2013 Author Report Posted March 20, 2013 No, I'm running a set of kicker 3.5s off of the head unit. And I have an old school boss audio havoc amp running a set of sc6.5 Boston acoustic components and a set of t1 fosgate components. And then for woofers I have 2 DD3512s firing forward sealed off on 2500w rms... I'm only running the kicker 3.5s for a little more sound up front... I'll just turn the head unit up to where my kickers begin to distort and set my gains accordingly to that level of volume. Then my system will be maximized correct?
Bradprobert Posted March 20, 2013 Report Posted March 20, 2013 No, I'm running a set of kicker 3.5s off of the head unit. And I have an old school boss audio havoc amp running a set of sc6.5 Boston acoustic components and a set of t1 fosgate components. And then for woofers I have 2 DD3512s firing forward sealed off on 2500w rms... I'm only running the kicker 3.5s for a little more sound up front... I'll just turn the head unit up to where my kickers begin to distort and set my gains accordingly to that level of volume. Then my system will be maximized correct? correct [sharedmedia=garage:vehicles:2223] 4th-order under rear seat build log: http://www.stevemeadedesigns.com/board/topic/165708-4th-order-under-rear-seat-chevy-extended-cab/#entry2410477 SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
