AQ Bass Knob
hemisphere
Is this knob worth buying for my AQ2200.. i was about to order it off of their website but then i read the reviews and they said that the knobs fall apart and short out easily...
If this is true, then is there any of better quality bass control knobs that i can run off of my AQ2200?
Use an eq like the kicker kx3 and use the knob that comes with that. I've seen it installed and functioning like that. If that's what you mean.
Or just buy the bass knob. It's like $15? Who cares if it breaks in a year..
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
star2.pngunit goes bad
this is a great base control knop with a clip meter until it goes bad! im on my third one now and have had my amp for no more than 18 months.. eventually m knob starts to go bad and doesnt work any more causing the bass to cut in and out, something inside the knob itself must come loose, causing it to stop working...and then when i goto reorder it they are never in stock so clearly im not the only one having the problem
Reviewed by: Tony from chicago. on 8/24/2012
this guy went through 3 in 18 months... that's why i don't wanna waste money on something i'm going to have to constantly replace.
Get a pac Lc-1
how do i hook that up to my amp?
plus 1 to getting a pac. It goes in line in your rca's
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
I e had no issues with mine. Then again I get new amps every year haha
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
I vote for the Pac LC-1 too. Unless there is a specific reason you want the AQ knob
Just be aware that you will need to re-set your gain after installing the knob as it does quiet down the signal slightly
Get a pac Lc-1
You connect it to your rca's that go to your amp.
  • Who's Online   0 Members, 0 Anonymous, 1091 Guests (See full list)
