You will get them in kyle get the sand out and man up :P
Get the rear in today finish glassing tomorrow let it cure overnight should be good.
Or wear a mask for the first couple times the subs are playing lol
dude rock the gas mask while you're cruising! that would look legit... while shaking people's windows :twirl::ninja:
<img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800">
Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log!
If you're glassing, 2 layers. TB II and done son. If you didn't want to
glass, 3 layers. To add strength, is there a way you could do the first layer sunk INTO the shell and the next layer on the outside? I realize this would affect your interior volume, but get with your enclosure guys and see if that is doable.
My opinion is that doing it like that would strengthen your joint. It would be a stair stepped joint and stronger rather than just 90°. This again, is purely my opinion.
No.. it is NOT doable.. Where you see the baffle is where it needs to be.
I was told BIG THE BIGGEST SHELL YOU CAN.. well, i did, then, i hit 39 cubes.. lol
Sooooo..
Now you understand that, and see where i need to lay.. what and how would you do this?
I was gonna do 2 layers. A back bone of 2x's (like i did on the front baffle) on the OUTSIDE to get it to "land" where i want. Glass all seams on the inside. Resin everywhere.
then, a run of 2xs like i did on the outside... THOUGHTS PLEASE??
What about some steel angle and carriage bolts? That shit wouldn't be going anywhere. 2x4's would work also.
IMO if a joint in done right, there should be plenty of strength even without 2x's. I always like to go overkill though. :D
  • Who's Online   0 Members, 0 Anonymous, 2106 Guests (See full list)
