Two AQ3500.1's Draw and DC 7.5k Draw
OrionStang
Exactly on amp draw numbers are way off .. Ami you have alot of experience what's max amperage per amp? Like 5-600 each .. At 1ohm you won't be drawing near that .. Even the 7.5 at .5 will be maybe 6-700 amps .. I'd run what sounds best ..
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
you could get a pair of 7.5s to draw 1400+ but not 1
DC AUDIO
Phone Number
1(855)SPL-DBZZ
Built by Competitors, for Competitors.
Sorry maybe I was wrong???
When I said wcs I did all that at 11 volts. Maybe I should have mentioned that?
Also not sure how efficient an amp is at .5 ohm. I always heard that it gets terribly less efficient at .5 ohm versus 1 ohm so if most people think an amp is 70% efficient at 1 ohm I went with 50% at .5 ohm. Maybe 60% is a better efficiency rating?
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
OKay so here is some Facts for ya Ken
2 AQ3500s wired at 2 ohm strapped (1 ohm per amp)
Dynamic music 700 amps max if clipping
Burp 3 sec burst 800 amps max if clipping
Now both of those numbers are dependant on box rise, could be a + or - 100 amps depending on final impedance the amps "see".
That is also under the assumption you can hold 14.4+ volts, voltage drops amperage goes up a little as efficiency decreases, just like with clipping efficency decreases, cause amperage in rush and voltage drop if you can't supply the additional current.
DC 7,5k at .5
Dynamic music 600 amp max if clipping
Burp 3 sec 800 amp max if clipping
Same above statement applies for DC amp as well.
Hope that helps ya. 270 alt and 2 D3100s is not enough, you gonna drop into the 12s. Which is okay if you are fine with it.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
  • Who's Online   0 Members, 0 Anonymous, 1038 Guests (See full list)
