Swordlordboy1234 Posted April 8, 2013 Report Posted April 8, 2013 If you set with the dd1 and change anything afterwords like loudness or powerful EQ then you wasted your time. Everything off / flat... Sub level 6/6... Find distortion points of 40hz &1khz on -0db... Set gains on amps with -5db. Problem solved My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
deathcards Posted April 8, 2013 Report Posted April 8, 2013 If you set with the dd1 and change anything afterwords like loudness or powerful EQ then you wasted your time. Everything off / flat... Sub level 6/6... Find distortion points of 40hz &1khz on -0db... Set gains on amps with -5db. Problem solved why 6 of 6 it can be too much of a good thing skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
Trey_Dog650 Posted April 8, 2013 Report Posted April 8, 2013 Most radios don't put out full output unless the level is set that way 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
Swordlordboy1234 Posted April 8, 2013 Report Posted April 8, 2013 Most radios don't put out full output unless the level is set that way This....... My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Big-A Posted April 8, 2013 Report Posted April 8, 2013 x10 on no eq and no loudness 2004 Dodge Ram Head unit- Alpine iDA-x305s Sound processor- Clarion eqs746 Mids/Highs amp- Alpine MRV-F345 Sub Amp- Alpine MRD-M1005 Dash Speakers- (3) Dayton Audio rs75 Front Door- Skar SPX65c Rear fill- Skar SPX tweters and Dayton ND140 midbass Sub- Fi Audio SSD 15 high QTS SHCA power/ground cables and Stinger interconnect XS power D6500 under the hood and D680 in the amp rack Big 3+ with SHCA http://www.stevemeadedesigns.com/board/topic/161174-dodge-ram-quad-cab-fi-ssd15-skar-audio-alpine-shca/?p=2326251
Swordlordboy1234 Posted April 8, 2013 Report Posted April 8, 2013 x10 on no eq and no loudness X 40000000 My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Noel989 Posted April 8, 2013 Report Posted April 8, 2013 Most radios don't put out full output unless the level is set that wayThis....... Mine goes up to 10 lol If I go pass 6 it distorts even if I'm at low volume so I just keep it at zero Build Log - http://www.stevemead...-cruiser-el-pt/
Swordlordboy1234 Posted April 8, 2013 Report Posted April 8, 2013 Most radios don't put out full output unless the level is set that wayThis....... Mine goes up to 10 lol If I go pass 6 it distorts even if I'm at low volume so I just keep it at zero MOST headunits. In this instance its true for pioneers with the subwoofer level not clipping the signal but should still use the dd1 to check... I had it on 0... Found bass distorted at 60/62... Then turned subwoofer level from 0/6 on volume 60... To 6/6 and still no distortion... Amp gain was lower after retuning with the dd1 for gains My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
bkolfo4 Posted April 8, 2013 Report Posted April 8, 2013 Bottom line is you are turning it up too loud. You can set the loudness however you want, and you can turn the bass boost up if you like, but then you cannot turn the volume up as high. You are trying to get more bass out of your system than it is setup to produce. . . Are you thermally killing the subs or ripping them apart mechanically? Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Kyle J Posted April 8, 2013 Author Report Posted April 8, 2013 Bottom line is you are turning it up too loud. You can set the loudness however you want, and you can turn the bass boost up if you like, but then you cannot turn the volume up as high. You are trying to get more bass out of your system than it is setup to produce. . . Are you thermally killing the subs or ripping them apart mechanically? Thermal. They look fine but of course the dust cap was warm so I'll assume the voice coils were toasted lol.. Wish I would've made this thread 4 Clipped subwoofers ago. $300 down the drain man lol.. I'm in High School and it took me forever to get everything all for nothing. Just installed my D3400 in the rear too haha My High School Build- 07' Civic Si Sedan Head Unit: Pioneer DEH-3500ui Sub Amp: (2) Hifonics BRZ1200.1D's Full Range Amp: Pioneer 75.4 Subs: (2) Skar Audio VVX12 V2 D2's Speakers: Pioneer 4-Way's x4 (RF's soon) Tweeters: (RF's or Alpine soon) XS Power D5100R Upfront XS Power D3400 in Trunk Knu Kolossus OFC 1/0 Power & Grounds Big 2/3 Wiring with 1/0 Gauge (Alt. is left)
