Noel989 Posted April 9, 2013 Report Posted April 9, 2013 Fluency in math and science is a definite plus in car audio. My 2 most favorite subjects Build Log - http://www.stevemead...-cruiser-el-pt/
john253a Posted April 9, 2013 Report Posted April 9, 2013 If they were the same model no Because more cone and 2x power When u go to different mdl You'll have same power more Xmas less cone So much the same very close box will deceid But if you go lvl5 or 6 1.5-2x power, more Xmas by atleast 25% less cone as we no But should be louder But will be
BassMunky Posted April 9, 2013 Report Posted April 9, 2013 huh^ Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
ThreehundredC Posted April 10, 2013 Report Posted April 10, 2013 so a square 15 is 225ish thats 25 from the 18 cone
BassMunky Posted April 10, 2013 Report Posted April 10, 2013 square arent that loud and clear Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Joe X Posted April 10, 2013 Report Posted April 10, 2013 The stiffness of the sub, the moving mass of the cone also are a deciding factor on how low a sub will play in addition to the enclosure. OP some single 18s can overtake some dual 15s, depending on the quality of the box but also in the subs themselves, for a given cone area the subwoofer with higher excursion will displace more air before bottoming out. But loudness to the ear is not the same as moving air, subjective loudness depends on frequency, you may want to do some research on equal loudness curves.
BassMunky Posted April 10, 2013 Report Posted April 10, 2013 hmmmmmmmmmmm Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
