help me out plz
mejweez
hello everybody :)
i want to make a ported box for 2 12" kenwood kfc-w3011
and am going to follow the recommendations on the manual
but the problem is that there is a design for a 1 sub only and it's with a round port
should i make two individual boxes or make two boxes with one common wall between them ??
will that make a difference ??
i will use a 3" pvc pipes
any advice on how to prevent noise ?
Use 2 3" ports. 1 per sub should be just fine. Make sure you have the proper length to achieve the tuning you want. a single 3" port could very well cause noise, which is why I'm suggesting 2. Im currently running a single 12" sub with 2 3" ports and it sounds great.
Seal your port to the size of the box on the INSIDE where the port meets up with the wood. Do a roundover but on the outside of the port entrance(with a router) and that will flare your port. That will help for better airflow
how much power you putting, what amp?
sealed will work well
so does ported, main factor recommend 37hz with 4sq" per ft with aero, personal that a bit low, but with only 11mm xmas
idd do a single 4" per sub @ 2net (depending on power) and as for hz that all depends on what u want to achieve
if you want look up psp ports you can get some nice flared port for not much coin
  • Who's Online   2 Members, 0 Anonymous, 471 Guests (See full list)
