bsneon98 Posted April 15, 2013 Report Posted April 15, 2013 hey guys im having a weird problem that I personally have never seen before.With my car running at idle, I used to have my 4 channel and my sub amp (just on, no load) with maybe .1 or .2 voltage drop.All of a sudden the other day my sub amp would draw me down to the low 10's with no music playing.After noticing my warranty is over on the amp I opened it up and saw that the caps may have some swelling on top.Any ideas? I'm mostly likely gonna buy a new amp but id like to fix this as a backup. Build Log: http://www.stevemeadedesigns.com/board/topic/152954-1998-plymouth-neon-updates/
Wicks Posted April 15, 2013 Report Posted April 15, 2013 At idle, an amp should never draw more than a few amps (if that). Sounds like the amp has an internal short and the power supply is drawing a lot of current because of it. Does the amp get hot? It should be if you're pulling the voltage down to the 10's. Is this with the subs connected or not? Make sure that you check them and verify that they are not involved in the issue. Caps bulge due to over-voltage and/or overheating. If they are bulged then they are more then likely damaged and won't operate like they should. Did any fuses blow? If the amp is acting like that and not protecting itself then it should definitely be sent in for repair or not used. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
bsneon98 Posted April 15, 2013 Author Report Posted April 15, 2013 At idle, an amp should never draw more than a few amps (if that). Sounds like the amp has an internal short and the power supply is drawing a lot of current because of it. Does the amp get hot? It should be if you're pulling the voltage down to the 10's. Is this with the subs connected or not? Make sure that you check them and verify that they are not involved in the issue. Caps bulge due to over-voltage and/or overheating. If they are bulged then they are more then likely damaged and won't operate like they should. Did any fuses blow? If the amp is acting like that and not protecting itself then it should definitely be sent in for repair or not used. The amp gets a little warmer than usual. I haven't left it on that long because of the nasty draw. Subs, Rcas, and bass knob were unplugged and the problem continued. All fuses are fine. Amp also doesn't protect and will still generate sound. Build Log: http://www.stevemeadedesigns.com/board/topic/152954-1998-plymouth-neon-updates/
SnowDrifter Posted April 15, 2013 Report Posted April 15, 2013 What if you unplug all your speaker wires from your amp? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Vito Basser Posted April 17, 2013 Report Posted April 17, 2013 What amp is it? Any pics of the board/caps?
fox_racin4 Posted April 17, 2013 Report Posted April 17, 2013 Where exactly are you measuring voltage at? 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
bsneon98 Posted April 17, 2013 Author Report Posted April 17, 2013 What if you unplug all your speaker wires from your amp? The problem continues What amp is it? Any pics of the board/caps? MB Quart ONYX 1.1500D no pics but there was no visible sign of any damage other than some swelling in the caps. Where exactly are you measuring voltage at? Directly at the amp Build Log: http://www.stevemeadedesigns.com/board/topic/152954-1998-plymouth-neon-updates/
SnowDrifter Posted April 17, 2013 Report Posted April 17, 2013 Now try this: With everything except the power/ground/remote wire disconnected from the amp, pick it up and wrap it in a towel or something. Just make sure the body of the amp is electrically isolated from the vehicle. See if it still does it ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
SnowDrifter Posted April 17, 2013 Report Posted April 17, 2013 Where exactly are you measuring voltage at? Directly at the amp Try measuring your voltage further down the line. At the battery ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
bsneon98 Posted April 18, 2013 Author Report Posted April 18, 2013 I finally had the time to triple check everything and the notorious neon trunk leak came back, and rusted my ground, causing a voltage drop.Sanded the shit out of everything and getting special grease for it this week, everything works perfect again! Build Log: http://www.stevemeadedesigns.com/board/topic/152954-1998-plymouth-neon-updates/
