do i need another run ?
Im running 1 run of 0 ga knu ofc kolossus wire with a 180 amp alt on 4k watts. i have 3 batts one xs1200 and 2 deka group 34 batts. My one run is about 30 feet, but im going to re route it so that im more along the lines of 20. it says a maximum of amperage of 325 amps can be pulled through a 20ft run if i remember right... im grounding to the frame so that run is parallel from positive to the positve in rear and then over to my other batt.
am i safe with one run or would i benefit from another run?
You don't necessarily need it but you are the point where you would benefit from it. You have to be at or close to the limit of that one run if you really have a 4kW load.
I'm gonna hate
right you are right on the line. Can you get away with it? the answer is ehhhhhhhhhh.
I always err on the side of caution its why ive got 6 and 6 runs in my truck.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I got 6 runs front to back for power/ground of CCA on 2kw :P Can never have enough overkill for electrical.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
why on earth would you spend that much in wire for that little draw?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Was $150 for 150 feet of wire, haha. I will be getting another 2k in a few weeks or so, so it's preparation as well.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
  • Who's Online   0 Members, 0 Anonymous, 2075 Guests (See full list)
