Stephen Dunnington Posted April 26, 2013 Author Report Posted April 26, 2013 Elec system what is it 2G, 3 Big, 80A Alt, no idea about the battery, it's brand new though.
Bradprobert Posted April 26, 2013 Report Posted April 26, 2013 I have the sq1200d and it would be the best amp to start with if you dont have any electrical upgrades and the correct equipment to set up a larger amp properly. edit: just saw your list and will say the sq1200 will be your best bet. [sharedmedia=garage:vehicles:2223] 4th-order under rear seat build log: http://www.stevemeadedesigns.com/board/topic/165708-4th-order-under-rear-seat-chevy-extended-cab/#entry2410477 SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
john253a Posted April 26, 2013 Report Posted April 26, 2013 The aq1200 is out of his budget at 430 The r1200 or mb1500 are 250 If you can push 400 there are a hep of better amps avaible
Bradprobert Posted April 26, 2013 Report Posted April 26, 2013 I paid 269 for mine. Amp kit cost 40. So total of 309. His budget was 300-350 right? [sharedmedia=garage:vehicles:2223] 4th-order under rear seat build log: http://www.stevemeadedesigns.com/board/topic/165708-4th-order-under-rear-seat-chevy-extended-cab/#entry2410477 SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
Omega5002 Posted April 26, 2013 Report Posted April 26, 2013 The SQ1200 is a great amp, but you'll gain the most when you build a proper box for those SA's. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Stephen Dunnington Posted April 27, 2013 Author Report Posted April 27, 2013 I have the sq1200d and it would be the best amp to start with if you dont have any electrical upgrades and the correct equipment to set up a larger amp properly. edit: just saw your list and will say the sq1200 will be your best bet. How exactly can I find this amp? Google doesn't seem to help.
Stephen Dunnington Posted April 27, 2013 Author Report Posted April 27, 2013 The SQ1200 is a great amp, but you'll gain the most when you build a proper box for those SA's. Any idea on how I can calcuate the perfect box? I can't go much bigger than what I already have. About an extra 3 inches in width, 5 inches in height, and plenty of length. Should I just build a box that is larger in length? This would also be my first box build
Bradprobert Posted April 27, 2013 Report Posted April 27, 2013 Here is the amp: http://www.soundqubed.com/Q1-1200D-Amplifier_p_30.html just buy it directly from them will be your best option. if you can post up the MAX dimensions you have, I or someone else on here can design you a box that will work the best. Some guys will charge you, some won't. I dont charge and I know for a fact JoeX does not either. [sharedmedia=garage:vehicles:2223] 4th-order under rear seat build log: http://www.stevemeadedesigns.com/board/topic/165708-4th-order-under-rear-seat-chevy-extended-cab/#entry2410477 SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
Krakin Posted April 27, 2013 Report Posted April 27, 2013 The SQ1200 is a great amp, but you'll gain the most when you build a proper box for those SA's. Any idea on how I can calculate the perfect box? I can't go much bigger than what I already have. About an extra 3 inches in width, 5 inches in height, and plenty of length. Should I just build a box that is larger in length? This would also be my first box build Post a thread in the subwoofer/enclosure section. Make sure you have max dimensions, what you want it tuned too/what music you play, and what amp you are going to pick for it with the wiring option picked. Such as 0.5-ohm (not advised without strong electrical, because damage caused by this isn't covered by most warrenties), 1-ohm, or 2-ohm. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
