What big " " did i just do? lol SKY HIGH WIRE FTW
so i have 2 wires off the power of the alt (3 if you include the factory power wire), 2 wires off the alt ground,
then the battery is grounded in 4 other places, strut tower, frame lower, frame upper, and factory ground location, what big " " would that be considered? lol
If you total everything up, there are 10 power and ground wires total under the hood. That is including the factory alt power wire, and factory ground.
Big 8? LOL
This does not include the power wires going back to the amplifier
i'd call it big 3. alt to bat, bat to chassis ground, chassis to block/alt ground. I don't care how many wires you have those are the 3 areas that need to be upgraded. But that's just me :P
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Just having all your wiring proper with solid connections is what counts.
As for what big " " it is, I would just count whatever you added on. For example if you had the normal big 3 plus an extra ground you could call it a big 4 I guess. I don't think there any official rules to it lol.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
  • Who's Online   1 Member, 0 Anonymous, 2433 Guests (See full list)
