SoundQubed Q1-3500D.1 Amplifier
Sky
It's not the same amp with different logo. It is similar but definitely not the same. Caps are differently arranged, dual inputs. Carrys a 4300 watt rating vs the previous 3500 watt rating. New one is fused at almost 800 amps between the two runs... Previous one was 400 amps.
It is the same smp. Plesse dont give advice if you dont know fir certain.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
The changes I mentioned don't constitute it being different enough from the previous model to be "new"? It couldn't be accurate to call it the same, could it?
Build's consist of:
2004 Chevy Impala :
Pioneer--------------------- DEH-X8600bs Soundqubed/AQ------ Q4-120
Rockford Fosgate---- Punch-500.4
Soundqubed/AQ----- Q1-3500D.1 Alpine----------------- 6.5's & 6x9's
Subs: TBA All Knukonceptz and SHCA wire and rca's
Home Music Setup
(4) Soundqubed HDS200 15's in two separate 15.5 cubic foot enclosures tuned to 31 hrz --- XM radio hardwire
Updates coming all the time on both builds
n8ball2013
"bullshit. Everything fits. If you cut enough."
The stuff you mentioned is from the AQ3500v1. The v2, which was available for a while, is the exact same amp as the SQ.
SMD Super Seller
My Feedback Thread
Youre wrong flat out. Thats all there is to it
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Misunderstanding.
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
800 amps is also the fuse rating for a strapped pair. Since its got dual 1/0 inputs. Its probably fused at no more than 600 amps. Bit I bet its 400. Im not pulling info from their site jusy goinf off the top of my head and knowing what fusing should be for a class d amp that makes 4300 watts.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
An off the top of the head of 600 amps was bout as good as it gets, but here, this is paste'd from an email from SQ a couple days ago:
DJ Is correct.
You will fuse each (If you use both) positive terminals with a 250-300A fuse. This is to protect the board on both inputs if anything were to go wrong. The amp does draw a lot, it will damn near take anything you can give it as long as it's clean!
Struck me as surprising, and that's why I went back and emailed them again about it. and ^ was the result
Beyond that DJ said it was appropriate to fuse each run at 380 amps. for 760amps of fusing total (If I got to feelin a little crazy with my impedance)
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
  • Who's Online   1 Member, 0 Anonymous, 1613 Guests (See full list)
