Pioneerchuck Posted November 28, 2013 Report Posted November 28, 2013 It's not the same amp with different logo. It is similar but definitely not the same. Caps are differently arranged, dual inputs. Carrys a 4300 watt rating vs the previous 3500 watt rating. New one is fused at almost 800 amps between the two runs... Previous one was 400 amps. You are thinking of the AQ 3500v.1 that amp had the original 1 set of 0ga inputs along with the different board layout. The AQ 3500v.2 had a redesigned board, dual inputs, and a higher power rating. As for it being fused at 800A that is not true at all..The v.2 is fused at a recommended 380A that would be 190a per input. So 190 on one set of inputs the other 190 on the 2nd set.
Impalalpine Posted November 28, 2013 Report Posted November 28, 2013 It's not the same amp with different logo. It is similar but definitely not the same. Caps are differently arranged, dual inputs. Carrys a 4300 watt rating vs the previous 3500 watt rating. New one is fused at almost 800 amps between the two runs... Previous one was 400 amps. You are thinking of the AQ 3500v.1 that amp had the original 1 set of 0ga inputs along with the different board layout. The AQ 3500v.2 had a redesigned board, dual inputs, and a higher power rating. As for it being fused at 800A that is not true at all..The v.2 is fused at a recommended 380A that would be 190a per input. So 190 on one set of inputs the other 190 on the 2nd set. I really thought so too, but.. the amp is rated at 4300 watts @1 ohm and fused @ 380 amps per power wire on 0 gage wire. It is rare that your amp will pull that much amperage so we usually recommend fusing at 250-300 amps per power wire. Each, your battery can send it's max amperage down each power wire to the amp. im not manufacturing these numbers. They are straight from DJ the owner of soundqubed. ^ above was the second part I couldn't find last night. But you heard the man, "380 amps per power wire" Build's consist of: 2004 Chevy Impala : Pioneer--------------------- DEH-X8600bs Soundqubed/AQ------ Q4-120 Rockford Fosgate---- Punch-500.4 Soundqubed/AQ----- Q1-3500D.1 Alpine----------------- 6.5's & 6x9's Subs: TBA All Knukonceptz and SHCA wire and rca's Home Music Setup (4) Soundqubed HDS200 15's in two separate 15.5 cubic foot enclosures tuned to 31 hrz --- XM radio hardwire Updates coming all the time on both builds n8ball2013 "bullshit. Everything fits. If you cut enough."
matt14 Posted November 28, 2013 Report Posted November 28, 2013 I just went to soundqubed site. I read about the " 380 amp per" and what I believe they are talking about is if you are running two 3500s in a linked/strapped configuration then that would be the fuse rating of " 760 for the pair". This is copied directly from the soundqubed site for the description of the SQ3500 The Q1-3500D.1 is one of our most powerful Amplifier with up to 7500 watts @ 1ohm @ 18volts for those guys and ladies who want to push their systems to the limit. You can strap a pair of Q1-3500D.1'S for a woofer busting 15000 watts @ 2ohm. Born in the same place as our popular Q1-1200D and Q1-2200D and built with the very best parts money can buy the Q1-3500D.1 offers the best watt per dollar value in its power range. WARNING You MUST have an upgraded electrical system sufficient to provide the amperage required to handle the 380 amp fuse rating of the Q1-3500D.1 (760 amps for a pair) in order to satisfy this beast. 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
n8ball2013 Posted November 28, 2013 Report Posted November 28, 2013 Considering a single lead of 1/0 is rsted at 300 amps of current draw I highly doubt dj is telling you to fuse it with 380 amps per lead. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
n8ball2013 Posted November 28, 2013 Report Posted November 28, 2013 Not to mention it would make that about the worlds.moost inefficient amp ever as thats the current draw for big boy amps in the 7k range THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
kl0wn Posted November 28, 2013 Report Posted November 28, 2013 To the OP, they are great amps. I have 1 ran at .5 to 4 SA-12's and they take it like champs. 2 of these amps on 4 of the X's will be nice 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
kandiman71874 Posted November 28, 2013 Report Posted November 28, 2013 Considering a single lead of 1/0 is rsted at 300 amps of current draw I highly doubt dj is telling you to fuse it with 380 amps per lead. Lets not forget here that the Amperage a wire can carry also depends on its length... A 2 foot section of quality 1/0 can carry a higher amount of amperage safely than a 20 foot section can. Daily Driver 1999 Kia Sephia Kenwood DNX-893s Audison Bit One Processor 2 Dat 4.125's Sundown Audio SCV-6k Hertz hsk-165xl's Mids running active Focal V30 Series Tweeters running active Sundown Sa-8 v1's in the doors 2 Sundown Zv5 12's Lots of Hushmat Big 3+ and 3 + & 3- runs of Trystar 2/0 2 Dc Power Engineering 320 HP Alts 2017 Comp Vehicle 2006 Toyota 4 Runner Kenwood Excelon DNX-893s Audison Bit One HD DSP 4 Sundown Sa 6.5v2 Component Sets Focal Access 6.5 2 ways Sundown Audio Sax-50.4 Sundown Audio Sax-100.4 2 Dc Power 370xp Northstar agm27f Northstar agm65 2 Northstar asmagm 480's 2 Dual 1 Sundown Nightshade v3 12's 2 Sundown SCV-7500's All SMD Fuse Holders Shitload Of Sundown 1/0 120 sq ft Second Skin Damp Pro No, Its Not A Burp Truck!!!! 2016 Season 3rd place in Xtreme 1 At Finals 2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations) 2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL David said: audio is a lifestyle, not a hobby newls1 I cant read a tape to save my life... 1/2's are ok, but other marks confuse me kingsuv only men who cant read a tape, take it in the ass kingsuv you sir, get a pink hard hat on jobsites
n8ball2013 Posted November 28, 2013 Report Posted November 28, 2013 I didnt want to go getting into that. Especially on mobile. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Impalalpine Posted November 28, 2013 Report Posted November 28, 2013 I tend to think of it less in terms of efficiency loss, (as it does 86% at 4 ohms) but in terms of the amp simply being overbuilt. I mean because an amp can put up with 780 amps of internal current doesn't mean that it calls for that all the time. Seems to me the amp is just a tank, and could consume my batteries all at once if it wanted to. It will probably draw 400 (or more) amps worth of current at one ohm (in an ideal world) but It can internally put up with double that. Build's consist of: 2004 Chevy Impala : Pioneer--------------------- DEH-X8600bs Soundqubed/AQ------ Q4-120 Rockford Fosgate---- Punch-500.4 Soundqubed/AQ----- Q1-3500D.1 Alpine----------------- 6.5's & 6x9's Subs: TBA All Knukonceptz and SHCA wire and rca's Home Music Setup (4) Soundqubed HDS200 15's in two separate 15.5 cubic foot enclosures tuned to 31 hrz --- XM radio hardwire Updates coming all the time on both builds n8ball2013 "bullshit. Everything fits. If you cut enough."
n8ball2013 Posted November 28, 2013 Report Posted November 28, 2013 Smh some people just dont get it nor admit they misinterpret things THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
