boostin302 Posted May 1, 2013 Report Share Posted May 1, 2013 hello guys. I have made a mold out of the expandable foam ( yellow top, red can) you get from walmart. it says its a polyurethane-based foam, can I use a polyester fiberglass resin over it to seal it up? foam: http://www.walmart.com/ip/Great-Stuff-Big-Gap-Filler-12-Oz/17300795 resin: http://www.oreillyauto.com/site/c/detail/BDO0/402/N0486.oap?ck=Search_N0486_-1_156&pt=N0486&ppt=C0171 My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/ 2001 Ford Mustang GT 4.6 SOHC 380HP 270 amp Mechman alt 2 12" Treo SSX custom built. 6.47 cu ft, tuned to 32Hz 2 hifonics Brutus 2400.1, strapped 1 optima yellow top 1 Kinetic HC1800 14.4v @ 29Hz, 2k RPM over 100ft 1/0 XS flex wire Big 3 in 1/0 100sq ft fatmat deadener 145.3 on music, 142.6 sealed on music Stop being a pussy and wall it off. I hate when my google breaks too I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines. Link to comment Share on other sites More sharing options...
ric006 Posted May 1, 2013 Report Share Posted May 1, 2013 i wouldnt trust great stuff man Link to comment Share on other sites More sharing options...
SnowDrifter Posted May 1, 2013 Report Share Posted May 1, 2013 Could you get some sort of water based paint and put a couple layers on top before moving to the resin?Squirt out a ball of foam and paint it in resin to see if it dissolves ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
boostin302 Posted May 1, 2013 Author Report Share Posted May 1, 2013 yeah i could get some water based paint if needed.. what would that do actually? besides maybe put a protective cover between the foam and resin i know resin produces heat and i think only thing that could go bad, is the foam melting and running all over the place. if that would be the case, could you mix in some extra hardener to get it set faster? My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/ 2001 Ford Mustang GT 4.6 SOHC 380HP 270 amp Mechman alt 2 12" Treo SSX custom built. 6.47 cu ft, tuned to 32Hz 2 hifonics Brutus 2400.1, strapped 1 optima yellow top 1 Kinetic HC1800 14.4v @ 29Hz, 2k RPM over 100ft 1/0 XS flex wire Big 3 in 1/0 100sq ft fatmat deadener 145.3 on music, 142.6 sealed on music Stop being a pussy and wall it off. I hate when my google breaks too I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines. Link to comment Share on other sites More sharing options...
Ben Fultz Posted May 1, 2013 Report Share Posted May 1, 2013 yeah i could get some water based paint if needed.. what would that do actually? besides maybe put a protective cover between the foam and resin i know resin produces heat and i think only thing that could go bad, is the foam melting and running all over the place. if that would be the case, could you mix in some extra hardener to get it set faster? That's the opposite of what you want to do, the more catalyst you use the hotter it gets, that's why it sets quicker. Your speeding up the chemical reaction, creating more heat in the process. Also the hotter you mix it, the more brittle it also becomes. Link to comment Share on other sites More sharing options...
Rell Posted May 1, 2013 Report Share Posted May 1, 2013 Could you post pics of this mold? Do you plan on pulling multiple parts from this mold or just one? How big is it? Foam wouldn't exactly be the best thing to use a mold to pull parts from. Im not sure on the exact differences between great stuff foam in a can from red top to yellow top. But I can tell you first hand that I have take a cured cut off price of great stuff foam from the yellow top can. I mixed up a really hot batch of resin and applied it to the foam and let it cure. The foam did not distort, melt etc in any way. I have heard of this foam melting with resin, however I'm not sure which of the cans people have used or if great stuff has made any changes to their product. If you have sanded any part of the foam to shape it or need to fill in any voids you can use plaster of pairs and mix it up with water and apply light coats to the foam and sand it after letting it cure. Apply more costs if needed. Link to comment Share on other sites More sharing options...
boostin302 Posted May 2, 2013 Author Report Share Posted May 2, 2013 i actually went out on a limb last night and emailed 3m (bondo) about it and they said that it should work perfect for my foam. since its a polyester resin and a polyurethane foam, it will work and cure to it right. the mold is actually for sealing off the trunk. if anything, i could just mix in a little bit less of hardener so the heat wont get that hot on it. My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/ 2001 Ford Mustang GT 4.6 SOHC 380HP 270 amp Mechman alt 2 12" Treo SSX custom built. 6.47 cu ft, tuned to 32Hz 2 hifonics Brutus 2400.1, strapped 1 optima yellow top 1 Kinetic HC1800 14.4v @ 29Hz, 2k RPM over 100ft 1/0 XS flex wire Big 3 in 1/0 100sq ft fatmat deadener 145.3 on music, 142.6 sealed on music Stop being a pussy and wall it off. I hate when my google breaks too I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines. Link to comment Share on other sites More sharing options...
boostin302 Posted May 2, 2013 Author Report Share Posted May 2, 2013 so I went ahead and bit the bullet on it tonight. mixed up some resin and hardener to what was recommended on the box, applied it and its working perfect. not melting the foam any and curing up nicely. only downfall I see is the foam just soaks up sooo much resin. My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/ 2001 Ford Mustang GT 4.6 SOHC 380HP 270 amp Mechman alt 2 12" Treo SSX custom built. 6.47 cu ft, tuned to 32Hz 2 hifonics Brutus 2400.1, strapped 1 optima yellow top 1 Kinetic HC1800 14.4v @ 29Hz, 2k RPM over 100ft 1/0 XS flex wire Big 3 in 1/0 100sq ft fatmat deadener 145.3 on music, 142.6 sealed on music Stop being a pussy and wall it off. I hate when my google breaks too I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines. Link to comment Share on other sites More sharing options...
audiofanaticz Posted May 2, 2013 Report Share Posted May 2, 2013 you wont have no issues. dont it tons of times already. Link to comment Share on other sites More sharing options...
