Alt turns on and off at idle WTF???
Stable up to 16v, but you charge at 16.xx daily? Im a lil CONfused?
I charge on the edge of what it can handle. Which is fine, until my voltage fluctuates like this
Watching the video again... I have a theory
Runaway voltage drop.
The voltage was dropping at the regulator because the regulator was drawing power to energize the alt. That voltage drop caused the regulator to think the voltage was lower than it really was, so it sent more power to the alt until it was going full field and the voltage caught up to what the setpoint was. Then it reduced the field current, reducing the power it was drawing, causing the voltage to go above the set point, so then it turns off for a second.
Rinse and repeat
Going to run some thicker wire from the alt (+) to the regulator. Will report back in a few minutes
Hmm... Ok... So that's what it was
I ran some 8ga straight from the alt to the regulator and it worked perfect.
Reminder: you can never have too much wire. Only too little ;)
im just wondering if it might be the external volt reg starting to go bad
My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/
2001 Ford Mustang GT
4.6 SOHC 380HP
270 amp Mechman alt
2 12" Treo SSX custom built.
6.47 cu ft, tuned to 32Hz
2 hifonics Brutus 2400.1, strapped
1 optima yellow top
1 Kinetic HC1800
14.4v @ 29Hz, 2k RPM
over 100ft 1/0 XS flex wire
Big 3 in 1/0
100sq ft fatmat deadener
145.3 on music, 142.6 sealed on music
Stop being a pussy and wall it off.
I hate when my google breaks too
I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines.
ninja.
dam, hit post and you fixed it
glad you got it man
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
  • Who's Online   0 Members, 0 Anonymous, 1093 Guests (See full list)
