I'm charging at 16.1-16.2. I'm not really sure if I should go with the normal VM-1 or wait for the high voltage one.
Here's what's on my mind:
The HV meter will read my charging voltage, but has a .4v resolution
The normal meter won't read my charging voltage, but has a better resolution of .3v.
Any input on this?
Do you need that finer resolution if your voltage is more stable with those monster caps?
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
what good does a meter with .3 resolution due if it cant read your charging voltage?
That's what I was wondering. Even though it can't read my voltage, will it be able to read the drop better?
That's what I'm not sure about :unknw:
Do I need it? lol
I'm getting a bigger amp. So I'm sure I'll be dropping some voltage. The caps store a ton of power and do great for stabilizing voltage spikes/dips. But I'm sure I'll be dropping
As long as the voltmeter displays your minimum allowable voltage and then has some room below that then you're fine.
The VM-1 is fast enough that you shouldn't need higher resolution as long as you can see the minimum that your voltage is dropping.
You'd also want the HV to see what you're charging at with a little room above that.
With the normal VM-1 you can't see of your overcharging which is important too.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
Can you use both of them on the same amplifier?
Well... I mean... Technically I COULD. But then there's the issue of why?
