I'm looking for two 12" woofers to run in 1 cu ft sealed boxes, the pair will be powered by an AQ 2200. Any suggestion on which Sundown sub would be best?
2006 Mustang GT
Audio:2x RF R1200-1D, 2x RF R400-4, 2x RF P1S48, 2x RF T1682c, 2x DC 12" Lvl 3 D2, 1x RF T1652-s, XS Power Batts, Toolmaker blocks, Knu wiring, Knu RCA's, custom enclosure with amp rack
Performance Mods:Too many to list...
2008 Toyota Tundra CrewMax 5.7L
Audio:1x RF R1200-1D, 1x RF R250x4, 2x Sundown 10" SD2, 2x RF P1652, 1x RF P1652-s, Q-logic kickpanels, Knu wiring, Knu RCA's, custom enclosure with amp rack
Performance Mods: Coming Soon
I'd imagine 100 extra watts would be nothing to the x series.
*New vehicle and system coming soon.*
It actually would be 150 less, and he'd have been to wait over a month. I'd go zv3 or sa. Zv3 gives room for upgrade
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
You could run 2 sa's on one 2200 easy.
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
i have 4 sa-d412's 2 hifonics brx 2000.1d class amps, so im puting a 1000 to each sub, air space for each is 1.6-1.8 but there ported and tuned at 35hz and i have to say i dont like the way they sound.wish i would have went bigger,just dont make that same mistake,do alot of research and go to youtube and check out other sundown setups
Do you wish you would have went with a bigger box? If so you are asking to break those subs. The sa12 works very well in a smaller enclosure. If you go any bigger than you are now you will start to harm the subs off that power. In my case now that I down graded setups to my new car, I have done 2 sa12's off a saz3500 at .5 ohms and I would bet you would like the way it would sound. Each sub sits in 1.4 cubes with approx. 9 sqin of port per cuft and is tuned to 37hz. The setup is loud and in the high 140 to low 150 db range.
Now when I had 4 sa12's off a pair of saz3500's I ran each sub in 1.56 cubes with 12sqin of port and was loud. If anything I would try shrinking your box before going bigger and retuning it to meet your particular style.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
I would go with an X... according to Jacob, they can take 2k daily. Assuming you have the electrical for it. Plenty of headroom for that AQ, especially since your talking about getting 2 subs.
http://www.stevemeadedesigns.com/board/topic/157471-sundown-x-10-x-15-x-18-prototypes-here/?p=2301866
When I hear music, I fear no danger. I am invulnerable. I see no foe. I am related to the earliest times, and to the latest.
~Henry David Thoreau
^ Maybe even 1 15" X or Z, if your planning on this being permanent. If you go with a 12", you do get the option of adding a second sub and amp later. :)
you like the new brx? i have the brz and it is a great amp. thinking about the brx series in the future
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
