Noob question: I've had my sundown comps for a couple months and they sound pretty good in my stock doors. I'm wondering what sound deadener will improve for me. I'm looking at the damplifier mainly beacause it's lighter, and the speaker tweaker kit. Compared to the stock doors, what difference will I notice by installing both of these? I don't have much rattling in the doors right now. Thanks
I haven't done mine but its a huge difference no sound escaping sounds way cleaner and plus if your running subs you want have the rattling noise.as a result you have stronger walls to keep the sound in.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
For me it helped with a lot of the rattles. And no more of that "slapping sheet metal in the wind" sound. Also helped with my flex
I was just thinking to myself, is that speaker tweaker kit actually worth while? I mean sure it could help when the window is up, but when it is down, wouldn't the window just obscure the speaker tweaker? I assume that most of us play our music with windows down. Unless it's like 10 degrees outside.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
hay man I'm from the south its hot as hell here my windows stays up during the day only at night I'll play the subs unless someone wants a demo.
2 sundown sd-2 d4
flex tech
box design by Joe X
I didn't think about the subs that's a good point. Will I get some nicer mid bass too or is that too much to ask out of the 6.5 mids? Good point on the windows too.
sound dampening generally gives you more midbass. as would the speaker tweaker with the window up. also if you seal up the door that will help midbass as well
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
