Single 12 Enclosure design?
Hey joe x. I was wondering if you could help me out do something like this for me . I have 2 15" American bass XFL's in a 1998 ford explorer 2 door. I'm looking for a box that's big , made to the specs of my subs , a really big port , and bangs the low notes I think? I think there the low notes . We'll anyways that makes really deep and loud bass . I would great apprciate it . Thanks you can message me if you want
If you have not done so make a thread mentioning your max dims and amp model. I will check it out.
Hey joe could you pm me? I think imma add those 2 45s that it shows in the pics. I cut all the pieces already now I just need to know the specs for the 45s. thanks! Im gunna start putting this together next week
Nothing for now...
Did you get that scar tissue when you got your vagina installed?
I'd grab Adam's ass and look him in the eyes for a demo of nates truck.
Dont bother with the 45s
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Really? wouldent the one in the port help a lot with air flow though?
Nothing for now...
Round or slant the inner edges of the port, at the turn and both ends. On the 45s it's your call, they will have little effect eitherway UNLESS you do the one inside the port the wrong size, that can ruin the build.
Hey joe...any way you could make a box with 6.6 cubes for 2 of these? I wont explain how I got a 2nd one just yet haha. Subs from slot port the in middle of them also? So that its a bit to ask. Max's you can change to about 16 tall, 35 wide, and 40 deep. Thanks man!
Nothing for now...
Ok here's a 2 subs version, check the notes below the sketch :
Enclosure Specifications:
Fb = 32 Hz
Vb = 4.6 ft^3
External Height = 14 in
External Width = 36 in
External Depth = 28 in
Port Width = 6 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2x Front = 15 x 12 1/2
2x Front Internal = 13 1/2 x 12 1/2
Back = 36 x 12 1/2
Left & Right Sides: 26 1/2 x 12 1/2
Top & Bottom = 36 x 28
Shared Port Internal Assembly Parts:
2 x Front to Back = 23 1/2 x 12 1/2
2 x Extension = 3 1/4 x 12 1/2
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.
- This box should be operated around subwoofer(s) rated power. If that´s not the case, let me know.
- The port needs 5" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Thanks man! Do you think I could build this inside the trunk actually?
Nothing for now...
You probably can but it's not the preferred way to go, I usually recommend doing a cardboard dummy box and keep changing it until it fits, also bear in mind that sometimes the box will fit from the cabin removing the backseats, need to keep trying ways, when you have working dims I can then try to mod the box.
IIAlright sounds good. Right now im swamped on school and work but hopefully this weekend I can tear out my seat and see if I can get it in that way. Otherwise I might build something in the trunk and face it into the cabin
Nothing for now...
  • Who's Online   0 Members, 0 Anonymous, 492 Guests (See full list)
