gattiboy13 Posted June 8, 2013 Report Posted June 8, 2013 I use to have CDT M6 and M6+. So I am looking for something that can keep up with those, but I can no longer afford them and saw these http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-919 any info on these would be appreciated.
TaylorFade Posted June 8, 2013 Report Posted June 8, 2013 These would be better. About the same price. http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-355 Those are a 7" woofer though so make sure they'll fit. Pretty close to a standard cutout, but a touch larger. These are basically impossible to beat for the price. http://www.madisoundspeakerstore.com/silver-flute-woofers-6-7/silver-flute-w17rc38-04-ohm-6-1/2-wool-cone/
SnowDrifter Posted June 8, 2013 Report Posted June 8, 2013 Sundown SD-8? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
bcbrassard Posted June 8, 2013 Report Posted June 8, 2013 Well if you had CDT then you had some of the beasts of midbass out there. The ones you posted looked a little low on power handling but for the price try them and see how they sound.
TRTC360 Posted June 8, 2013 Report Posted June 8, 2013 These would be better. About the same price. http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-355 Those are a 7" woofer though so make sure they'll fit. Pretty close to a standard cutout, but a touch larger. These are basically impossible to beat for the price. http://www.madisoundspeakerstore.com/silver-flute-woofers-6-7/silver-flute-w17rc38-04-ohm-6-1/2-wool-cone/ would those work as the woofer in a 2 way component set or would they be better suited for a 3 way setup? '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
SnowDrifter Posted June 8, 2013 Report Posted June 8, 2013 Tang band w6-1139sif ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
gattiboy13 Posted June 8, 2013 Author Report Posted June 8, 2013 Your right. I should be patient and save dor a few months and stick with cdt. Well if you had CDT then you had some of the beasts of midbass out there. The ones you posted looked a little low on power handling but for the price try them and see how they sound.
Kevin M Posted June 8, 2013 Report Posted June 8, 2013 These would be better. About the same price. http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-355 Those are a 7" woofer though so make sure they'll fit. Pretty close to a standard cutout, but a touch larger. These are basically impossible to beat for the price. http://www.madisoundspeakerstore.com/silver-flute-woofers-6-7/silver-flute-w17rc38-04-ohm-6-1/2-wool-cone/ would those work as the woofer in a 2 way component set or would they be better suited for a 3 way setup? The rs180 that Taylor Fade mentioned would be better as a midbass in a 3 way but the silver flute would work well in a 2 way. Here is another recommendation for a beast of a midbass... http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-1102 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle
TRTC360 Posted June 8, 2013 Report Posted June 8, 2013 These would be better. About the same price. http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-355 Those are a 7" woofer though so make sure they'll fit. Pretty close to a standard cutout, but a touch larger. These are basically impossible to beat for the price. http://www.madisoundspeakerstore.com/silver-flute-woofers-6-7/silver-flute-w17rc38-04-ohm-6-1/2-wool-cone/ would those work as the woofer in a 2 way component set or would they be better suited for a 3 way setup? The rs180 that Taylor Fade mentioned would be better as a midbass in a 3 way but the silver flute would work well in a 2 way. Here is another recommendation for a beast of a midbass... http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-1102 so if I tried to run the peerless you recommended or the dayton taylor recommended in a 2 way setup it would sound like i'm missing something? great low end but the midrange wouldn't really be there? I need to accompany them with anywhere from 3-5.25" midrange to make up for it? reason i'm asking is because i'm looking to replace my focal krx2 woofers because they are a little old and haven't been taken care of properly, i'm getting a weird clicking sound at high volume if I cross them below 100hz, and whatever I replace them with I want them to have more powerful midbass '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
