Is this a alt problem?
My buddy has a 98 durango, when you start the car, if you dont rev the engine up it dies, and the lower rpms make the lights dim. In his gauge cluster, he has a OEM volt meter, when the car starts its at 8, then after you rev it up, it slowly goes to 14. I think its the alt, Any opinions??
perhaps turn the idle up?
If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved.
It sounds like the battery. A healthy battery should never be at 8 volts.
X2 on that a good batt will not sit that low. However it could be a combinantion of both and a bad batt will trash an alt real quick. If it was me I would replace them both
Or tell him to go to a local parts store and have his electrical checked. A lot of local part stores will do ot free.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
One more thing dont ever trust the stock volt meters. mine reads 12 volts while my dmm reads 14.3 volts.
if its not used for hi draw car audio and its a wet cell battery I would first top off the battery with distilled water and try to put a charge on it before I go buying a bunch of stuff
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
check it with a dmm . it would not start if the battery was really below 12v unless you jumped it
REP
  • Who's Online   0 Members, 0 Anonymous, 2075 Guests (See full list)
