IH8PunkRok Posted October 5, 2014 Report Posted October 5, 2014 Adding power will tell you what the issue really is. -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
gckless Posted October 5, 2014 Author Report Posted October 5, 2014 Adding power will tell you what the issue really is. How? I've got some clean juice in the amp left, just been afraid to give it more because of what I'm already seeing. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
ToNasty Posted October 5, 2014 Report Posted October 5, 2014 i know this might sound dumb but i had a similar problem with my sa when i had it, the tuning maybe to low? i remember i upped the tuning on my box and the issue went away ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
tacomaguy1 Posted October 5, 2014 Report Posted October 5, 2014 These need to be tuned low I think tfade did testing with one and that's what he found Team Flex Issues
IH8PunkRok Posted October 5, 2014 Report Posted October 5, 2014 Adding power will tell you what the issue really is.How? I've got some clean juice in the amp left, just been afraid to give it more because of what I'm already seeing.Something will break or it will fix the issue -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
gckless Posted October 5, 2014 Author Report Posted October 5, 2014 Adding power will tell you what the issue really is.How? I've got some clean juice in the amp left, just been afraid to give it more because of what I'm already seeing.Something will break or it will fix the issue I'm trying not to buy a $250 recone here... "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
RossGo Posted October 5, 2014 Report Posted October 5, 2014 I got an infrared heat gun off amazon for like $15You could probably shoot it through your plexi to check coil temp Yes I have a lot of stereo weight. I build for Smiles Per Gallon not Miles Per Gallon LOLZ My build - 1996 4Runner with 2 18s - 149+ in a sealed box (with radiators)
gckless Posted October 6, 2014 Author Report Posted October 6, 2014 I got an infrared heat gun off amazon for like $15 You could probably shoot it through your plexi to check coil temp I have one that I used for nitro RCs. Just checked and I guess the battery is dead, I'll get another one. I really don't think it's going to pick it up though, the opening where I can see the coil is about .25" thick or less, and the plexi is about 10" from the coil. Doubt what I have is accurate enough. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
gckless Posted October 6, 2014 Author Report Posted October 6, 2014 Got a couple things I'm gonna try, but if that don't work, this big bitch is coming out. Simply not enough space in here. Already have another setup in mind "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
2000LaDe Posted October 6, 2014 Report Posted October 6, 2014 If everything the guy is doing is right and he's certain the signal is clean why is the sub not being able to handled rated being ruled out? Seems like quite a few people have said tantric subs get hot and smelly on rated or just over rated power, which is exactly what he's experiencing but people wanna blame it on his electrical, box and music signal. I'm not trying to bash tantric here cause they're great sounding subs and seem to be in a lot of loud builds, I just feel I have enough evidence from builds I've seen to say they might not be able to handle rated power or they can but you have to be ultra conservative. I dont know you but the guys name is gckless. Quite rude and disrespectful... Next thing is that I have heard No-one speak of tantric getting hot quickly unless there is some underlying issue. They do get the tantric smell due to the coils being coated. Lastly, I as well as MANY others can attest that tantric subs do more than rated on average. I personally was running 2 shd's on 20k.... true story. tantric coils brand new before even put into the subs have a smell. its a pretty distinct smell too. so even when you play them they make that smell. its just the coil and how he has them made. they smell like shit naturally haha. but trust me even if they are smelling that doesnt mean they are hot just means they stink lol. eventually the smell works its way out after you get the coil hot and let it cool off several times. just got to work the coil that way.
