2003 Kia Sorento Build log (Pair of Team AA 15's in and playing)
Where are you grounding your amp? because I have a 2013 kia sorento and I can't seem to find a ground. I've hooked everything up and get a heartbeat noise from my subwoofer. I can't figure it out.
I'm planing on grounding my amplifiers to the 2nd battery, which is grounded via to the frame, and a negative run from the starter battery.
You are probably getting noise because the newer model Sorentos are a unibody car while I have the first generation Sorento with a truck frame. I don't know much about the new Sorento's, so I really can't help there :/
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Just an update, did some few things
First off, bought a voltmeter, and some switches for the coin holder, which I don't have to modify or drill, already a hole behind it to run wire
Also decided to install another fuse holder for the positive run for the 2nd battery
Also installed some better aluminum battery terminals to have a better secure installation for the wires since the stock terminals wasn't 100% secure, though had to use one of my battery terminals for the stock positive connection due to the fuse box, and it couldn't fit on the terminal
And the biggest part of this update, some tweeters that SLAYER1805 sent to me :)
A pair of Ascendant Audio Havoc tweeters, which will go on stock location
2003 Kia Sorento
Team Subsonic Lows
  • 3 weeks later...
So I got bored one day, and wanted to see if my box that didn't fit the volvo would fit the sorento
And it does!
Also started the positive run
Negative run done
Frame ground
2003 Kia Sorento
Team Subsonic Lows
Made the amp rack out of random scrap parts, it's temporary
Voltmeter/Switch panel
Terminals
Amp installed
2003 Kia Sorento
Team Subsonic Lows
Loading up the subs
Battery terminals in
2003 Kia Sorento
Team Subsonic Lows
So far, I like the way the box sounds so far, the lows are more intense
Gonna put up a video soon
Also got myself a new toy
2003 Kia Sorento
Team Subsonic Lows
Just a small update, went to visit my buddy Dennis at his shop to get metered, and learn my peak before the next show on sunday, and after some testing
These are sealed up in the dash scores
- 139.9 at 35hz
- 140.2 at 40hz
- 140.1 at 45hz
Sealed up I peak at 40hz, driver door open I peak at 44hz
This is the score with the driver door open, in the kick at 44hz
143.0
Also got some more goodies
Got myself a stinger voltmeter cause my current voltmeter is impossible to read in sunlight, and a volt off, so got myself the stinger, and I got myself a good book :)
2003 Kia Sorento
Team Subsonic Lows
Good numbers out of a box that wasn't specifically built for the Kia! Can only get louder from here :good:
  • Who's Online   0 Members, 0 Anonymous, 404 Guests (See full list)
