95 south Posted June 27, 2013 Report Posted June 27, 2013 I was wondering how do you charge your rear batteries at night with the XS Power Intel charger? Do I have to remove the power wire from each battery to charge it? All 4 batteries are connected parallel to each other. No System......GFY
Ben Fultz Posted June 27, 2013 Report Posted June 27, 2013 Just hook up charger to any battery, when they are hooked up the chargers sees them as one big battery.
95 south Posted June 27, 2013 Author Report Posted June 27, 2013 Ok cool...thank you No System......GFY
Kyblack76 Posted June 27, 2013 Report Posted June 27, 2013 Leave em all hooked up, and toss the charger on em.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
kbsmoker Posted June 27, 2013 Report Posted June 27, 2013 That will work but not best. Would be better to have your positive on one end of your bank and negative at the other end to force the charge through all the batteries evenly. www.dcsoundlab.comyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3 SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator
95 south Posted June 27, 2013 Author Report Posted June 27, 2013 I can do that as well. I am glad I don't have to uninstall them to charge them....That would be painful No System......GFY
SnowDrifter Posted June 27, 2013 Report Posted June 27, 2013 Hook it to any batt and you are good to go. They are all paralleled with your wiring anyway. And you don't need to hook the pos up to one end and the neg on the other just FYI. The difference in voltage between the batt the charger is wired to and the other batteries isn't even enough to measure. Certainly not enough to create any difference in charging performance or unequal charging ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
95 south Posted June 28, 2013 Author Report Posted June 28, 2013 Ok thanks guys for all the inputs. This forum helps a lot. No System......GFY
