0 gauge for alt querstion?
You're good as long as you have the other 2 components of the Big 3 done.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
That's the problem. Where am I grounding the other 2 wires? The side frame of my SUV is not good and I don't know where to ground the engine? Its driving me nuts because it seems no matter how much wire I run my voltage drops fast due to poor grounding up front.
No System......GFY
Ground your battery and your block to the same spot. Ideal spot is a thick heavy metal part of the frame. Take some pics of your engine bay.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
depends on the resistance, but let me tell you, we added 2 more extra runs from alt to battery, now my teammate has 2 pos and 2 neg from alt to battery and did a BIG difference :)
Big3? not bad, i always recommend doing at least the big4, same big3 but adding a run from alt to battery, that helps a lot , specially when you have an aftermarket HO alternator ;)
