christamez80 Posted July 1, 2013 Report Posted July 1, 2013 Ok so I finally was able to meter my setup. I'm new to this and not sure if this is good or not. To start off I have a 05 Tahoe with 4 Obsidian Audio 18's in a 23.28 cu ft box tuned to around 32 hz. 2 RE Audio XTX5000.1 on subs at 1 ohm each amp. XS Power D3100 in back and XS Power D925 in front. Stock alternator. I do have a Mechman 270 now but metered it with stock. I played music and it read a 149.6 in the kick, is this pretty good on music? Never metered before so I don't know what to expect. I have put the alternator now a wanna meter it again. What kinda bass tone should I play when I meter it? I played a 32 hz tone last time. I was told later on I should have done a 40 hz tone. What do you guys think?
will77530 Posted July 1, 2013 Report Posted July 1, 2013 uhhhh not really, find your peak and re meter
christamez80 Posted July 1, 2013 Author Report Posted July 1, 2013 Not walled...subs are pointing up with the port facing the hatch.
tacomaguy1 Posted July 1, 2013 Report Posted July 1, 2013 Pics?...how tall is the box, too tall and could be blocking air flow Team Flex Issues
christamez80 Posted July 1, 2013 Author Report Posted July 1, 2013 the box is 48 wide x 27 height x 40 length. All pieces are 1 inch thick except top which is 1 1/2 inch thick. I measured the port from hatch and its 3 inches from touching. Im thinking of building another box that is 48 x 38 x 24. would this help more? and also building it with interchangeable ports.
christamez80 Posted July 1, 2013 Author Report Posted July 1, 2013 This is the box when I was working on it.
Trey_Dog650 Posted July 1, 2013 Report Posted July 1, 2013 Yeah pretty tall. 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
tacomaguy1 Posted July 1, 2013 Report Posted July 1, 2013 Way too tall to ever meter good Team Flex Issues
christamez80 Posted July 1, 2013 Author Report Posted July 1, 2013 You guys think if I go 3 inches shorter and tune the new box around 35 hz, it would sound better and meter better?
