(solved)for unknown reason orion sub putting amp into protect mode.
Terry Lee
Hopefully someone with more knowledge chimes in.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
god damn that woofer sounds like shit. you're probably gonna fuck it up if you keep doing that.
make sure the speaker wire going into the terminals on the sub isn't touching the frame behind the terminals. aka sticking the speaker wire in too far and having it touch the metal basket. this will cause a short.
measure resistance by turning the meter to this thing
take the cap out. its likely useless.
the ohms measured at 2 on each side. adjusting the speaker wires didnt do anything.
Try setting your gain at about 25%. Set the xover to a guesstimated 80hz. And put the bass boost at 50%.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
looks like to me the coils going out or check the speaker wire
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
better yet, turn bassboost off and superglue it off. absolutely useless feature 99% of the time.
OP doesn't have his headunit volume up high enough to yield sufficient preout voltage, or the subwoofer level isn't up all the way on the headunit.
Damn that thing sounds like ass even for being out of box. Probably clipping the shit out of it.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Bad advice is bad. Gain position is different for everyone, and bass boost needs to be completely off.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
