kingsuv Posted July 11, 2013 Report Posted July 11, 2013 Plastic which most car audio fuse holders are made out of have a lower melting temp VS. the Nylon product like the link I posted. Combine that with a bigger mounting studs, you have a better and much safer product in high current applications. Designing, building, and shipping boxes. Yahoo IM - kingsuv00If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out. not many cars can get me to pluggin my ears but this one.......damn. I mean the first minute is ok but that thing just really starts digging deeper and deeper in your earhole till you cant stand it no more. Seems like it does it with relative ease....16 12's on 8 amps.........gotta love it.
SnowDrifter Posted July 11, 2013 Report Posted July 11, 2013 Fusing is not to protect the wire..its to keep it from SHORTING and or ruining equipment. Fusing the wire is to protect the wire... shorting or grounding the wire out without having a fuse can turn the car into a big ole burst of flame. Amplifiers have built in protection circuits, that's why they have a protection light. Pretty much.... It's there to protect against a short circuit scenario and the huge amount of heat that comes with it. Whether it be a wire shorting out, or equipment failing. It will stop you from having an uncontrolled inferno. When people say fuse to protect the wire, they mean that you fuse the wire so that should the insulation rub through and it shorts out, it will interrupt the flow of current - a safety consideration. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
SMZ2 Posted July 12, 2013 Author Report Posted July 12, 2013 I had looked at the second fuse holders you had posted kingsuv. Like it was said early I would only need a 300 amp fuse because my alt is a 270 amp correct? Also I would fuse on each ends of the battery bank right? My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
SMZ2 Posted July 12, 2013 Author Report Posted July 12, 2013 I saw the 500 amp fuses on the site kingsuv posted. Shouldn't I fuse for how many amps the wire will carry? My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
f150on33s Posted July 12, 2013 Report Posted July 12, 2013 I had looked at the second fuse holders you had posted kingsuv. Like it was said early I would only need a 300 amp fuse because my alt is a 270 amp correct? Also I would fuse on each ends of the battery bank right? 300 amp fuse should be find. Always fuse a power wire, whether they are off the alt or a battery. Rule of thumb is "If you think it needs a fuse, you need a fuse." 2003 F-150 Single Cab Pioneer 80prs All KnuKonceptz 0ga Wiring (all soldered using Sky High Lugs) Sky High Fuse holders Big 3 with redtop Karma SS RCAs Eclipse EA4000 for Mids Rockford Fosgate Punch Pro 6.5s Crescendo RTS-1 tweets Audio Technix AT1200.1d for Sub Soundqubed HDS312 Box 2.65cubes @ 32Hz 6'' Aero port Stock 130 Alt (looking at a Singer 270 Alt)
IBleedMusick Posted July 12, 2013 Report Posted July 12, 2013 Let's not get into the fuse/not fuse debate please. Because there are enough people who do and don't to derail this thread completely. 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback
Swordlordboy1234 Posted July 12, 2013 Report Posted July 12, 2013 Let's not get into the fuse/not fuse debate please. Because there are enough people who do and don't to derail this thread completely. Tell Jon that a 2/0 holder is needed for his 2/0 wire... But from what little birds have told me he might need new fuse holders after he gets done with the new 2/0's My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
SMZ2 Posted July 12, 2013 Author Report Posted July 12, 2013 I will be fusing. I just need to know what fuses size to use. When I talked to Jon he said a 500 amp fuse, but I didn't tell him my how many amps my alt is. I was told this wire can carry up too 600 amps. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
