BEEMDUB Posted July 10, 2013 Report Posted July 10, 2013 I know in the instructions they're real big on using an oscope...Is it possible to do it without one and not totally screw things up? What process do you normally use for first time config on a 3sixty2? I only have one 6.75 comp set up front and rear door speakers off a mbquart 4 channel so its nothing to complicated, I've just never worked with any sound processor as complicated as the 3sixty so I don't really know where to start haha
hdorre Posted July 10, 2013 Report Posted July 10, 2013 Turn the gain on the 3sixty down a bit. Turn up the HU volume until you see the red LED by the input. Turn the volume down 1. There's your volume. Now tune the actual 3sixty accordingly. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
BEEMDUB Posted July 10, 2013 Author Report Posted July 10, 2013 Turn the gain on the 3sixty down a bit. Turn up the HU volume until you see the red LED by the input. Turn the volume down 1. There's your volume. Now tune the actual 3sixty accordingly. I actually am running 3.5mm to rca from my in dash tablet to the 3sixty will I still do the same thing? and so the 3sixty has like a built in clipping indicator led your saying?
BEEMDUB Posted July 12, 2013 Author Report Posted July 12, 2013 so right now my setup goes Galaxy tab 2 7.0 > Hifonics HFEQ > MB Quart 4 channel amp the amp is wired to the speakers like this channel 1: to passive crossover that goes to 6.75 door speaker and to tweeter channel 2: to passive crossover that goes to 6.75 door speaker and to tweeter channel 3: to factory rear door speaker and tweeter channel 4: to factory rear door speaker and tweeter The passive crossovers seem like a waste with the 360 so how should I wire the speakers to the amp?
Ratonul Posted November 26, 2016 Report Posted November 26, 2016 how do i setup time delay on 3sixty.2 ? what these simbols ' " mean ? inch, feet, ms? if i have 150cm to the speaker what do i put in ?
06RTCharger Posted November 27, 2016 Report Posted November 27, 2016 how do i setup time delay on 3sixty.2 ? what these simbols ' " mean ? inch, feet, ms? if i have 150cm to the speaker what do i put in ? 1'2"=one foot and two inches. Just some additional info for u incase ur not familiar, 12 inches make 1foot. 76inches for example is 6'4". U can convert ur measurements on google
3vil Posted November 27, 2016 Report Posted November 27, 2016 I'm not familiar with the 3sixty line, is there way to convert units to centimeters? I'm all for imperial, but for time alignment foot+inch seems rather imprecise.
Ratonul Posted November 30, 2016 Report Posted November 30, 2016 1'2"=one foot and two inches. Just some additional info for u incase ur not familiar, 12 inches make 1foot. 76inches for example is 6'4". U can convert ur measurements on google http://rftech.custhelp.com/app/answers/detail/a_id/864/~/understanding-the-3sixty.1%2F3sixty.2-delay here it says that if you have 24" diference between the speakers you enter 2'4". not 2 feet.... if i have 6.5" woofer and tweeter on the same channel but the woofer is 20" away and the tweeter is 15" away, what delay do i put in ?
MrSkippyJ Posted November 30, 2016 Report Posted November 30, 2016 No what it says is that you may find that even though you have 24" of difference, 2'4" might sound best. The best way to decide what delay works best is to use your ears. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Kyblack76 Posted November 30, 2016 Report Posted November 30, 2016 You want people, that live across the nation from you, to set your time alingment up in your vehicle? Bro, sit in it, and play with it, when it sounds good to you. Stop. Done. If your asking these questions, maybe that dsp is a bit over your head. No disrespect ment. Also, you have the tweeter and mid on the same channel? Then, Yes, the TA will be the same on both. You cant control each driver, individually, being on the same channel eh? so how are you cutting the tweeter? Passively ? Why do you even have the dsp then? Just for TA ? And TA only ? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
