RF 3Sixty.2 Questions!
I know in the instructions they're real big on using an oscope...Is it possible to do it without one and not totally screw things up? What process do you normally use for first time config on a 3sixty2? I only have one 6.75 comp set up front and rear door speakers off a mbquart 4 channel so its nothing to complicated, I've just never worked with any sound processor as complicated as the 3sixty so I don't really know where to start haha
Turn the gain on the 3sixty down a bit. Turn up the HU volume until you see the red LED by the input. Turn the volume down 1. There's your volume. Now tune the actual 3sixty accordingly.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I actually am running 3.5mm to rca from my in dash tablet to the 3sixty will I still do the same thing? and so the 3sixty has like a built in clipping indicator led your saying?
so right now my setup goes
Galaxy tab 2 7.0 > Hifonics HFEQ > MB Quart 4 channel amp
the amp is wired to the speakers like this
channel 1: to passive crossover that goes to 6.75 door speaker and to tweeter
channel 2: to passive crossover that goes to 6.75 door speaker and to tweeter
channel 3: to factory rear door speaker and tweeter
channel 4: to factory rear door speaker and tweeter
The passive crossovers seem like a waste with the 360 so how should I wire the speakers to the amp?
  • 3 years later...
how do i setup time delay on 3sixty.2 ? what these simbols ' " mean ? inch, feet, ms? if i have 150cm to the speaker what do i put in ?
1'2"=one foot and two inches. Just some additional info for u incase ur not familiar, 12 inches make 1foot. 76inches for example is 6'4". U can convert ur measurements on google
http://rftech.custhelp.com/app/answers/detail/a_id/864/~/understanding-the-3sixty.1%2F3sixty.2-delay
here it says that if you have 24" diference between the speakers you enter 2'4". not 2 feet....
if i have 6.5" woofer and tweeter on the same channel but the woofer is 20" away and the tweeter is 15" away, what delay do i put in ?
No what it says is that you may find that even though you have 24" of difference, 2'4" might sound best. The best way to decide what delay works best is to use your ears.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
You want people, that live across the nation from you, to set your time alingment up in your vehicle?
Bro, sit in it, and play with it, when it sounds good to you. Stop. Done. If your asking these questions, maybe that dsp is a bit over your head. No disrespect ment.
Also, you have the tweeter and mid on the same channel? Then, Yes, the TA will be the same on both. You cant control each driver, individually, being on the same channel eh?
so how are you cutting the tweeter? Passively ? Why do you even have the dsp then? Just for TA ? And TA only ?
  • Who's Online   0 Members, 0 Anonymous, 1047 Guests (See full list)
