John62591 Posted September 1, 2013 Report Posted September 1, 2013 A 4x4 equipped vehicle is used primarily for hauling and off roading, not much as a daily driver. Anyhow, a clean air filter, spark plugs, new oil and oil filter, clean sensors and intake manifold, cutting the exhaust from the last O2 sensor towards the muffler, replacing PCV valves with small filters, having a manual transmission, buying a toyota. Weight reduction - Pretty much demo derby style; Remove; dashboard, lights, bumpers, hood, doors, bed/tailgate, roof, stereo, glove box, exhaust system, charcoal canister, air box, EGR system, windshield wiper fluid tank, cigarette lighter (maybe), mirrors, windows A/C, Climate control, plastic cover for steering column, rim covers, seats, and girlfriend. Swap; 4x4 differential, drive line, to a holley intake, transmission, to aluminum heads/Valve Covers, ADD; Another gas tank, kittens, and tuna fish. ......Seems a little redneck..hmmm
justin0943 Posted September 2, 2013 Report Posted September 2, 2013 buying a toyota. I got a buddy that has a 2wd 4 cylinder 02 toyota an he gets less mpg then mine v6 97 dakota, like I said the best way is take the manual fan and put in electric fans in extra 3-4 mpg and 3-4 hp 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
justin0943 Posted September 2, 2013 Report Posted September 2, 2013 heres the ep its a 96 dodge ram 1500 they get 8-10mpg before, after they install all the stuff they double to 16-20mpg http://www.spike.com/episodes/288bjy/powerblock-xtreme-4x4-fuel-saving-street-truck-start-to-finish-season-3-ep-137 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Baydestrian Posted September 3, 2013 Report Posted September 3, 2013 The speed thing is funny, my instant MPG tells me I get slightly better MPG going about 68-72 than I do going 65. I think my 99 Caddy was the same way 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
John62591 Posted September 3, 2013 Report Posted September 3, 2013 heres the ep its a 96 dodge ram 1500 they get 8-10mpg before, after they install all the stuff they double to 16-20mpg http://www.spike.com/episodes/288bjy/powerblock-xtreme-4x4-fuel-saving-street-truck-start-to-finish-season-3-ep-137 Vedy nice. Don't forget the kittens. Good thing the front tires weren't on the back and the back wasn't on the front cuz that can cause you a big headache lol. Funny video, ( )
Mustang06331 Posted October 1, 2013 Report Posted October 1, 2013 Best tip in the world is to stay on top of your tire pressure . Ever tried to push a car w a flat???? Works the same under engines power. Stay on top of oil changes and use synthetic. If at all poss reduce rotating mass . Every 10 lbs of rotating mass is equal to 100 lbs of dead weight
Goblenator Posted January 30, 2014 Report Posted January 30, 2014 switch the the fluids to royal purple. i did this in my dakota and got 2 mpg. U could also do an underdrive pulley system to free up the motor and a throttle body spacer which helps het better combustion
Katt Posted January 30, 2014 Report Posted January 30, 2014 Bit of a bump, lol. If you never use your 4x4, take the front shaft out. Buddy bought a 95 Tahoe, without one. And he noticed when he put the front shaft in, he got worse mpg...but it also was a hog anyways, but yeah lol. I've had better results spending a few more $$ at the pump running 93, rather then 87. Get more mpg out of it. Seafoam works too, as said before. Fuel tank additive. As said, take off slower, coast to stop lights, light changes, then you're still rolling rather then stopped. Then just keep in mind, is it really worth it to waste gas to speed up to a stop sign / red light / slowass car? Make sure no exhaust leaks, Make sure your O2 sensors aren't junk. Exhaust leak is what killed part of my gas eating, Letting in more air, making it think running lean, pouring in more fuel.. I'll think of shit later, I'm in the same boat, doing as above, going from a 1.5L 4 Cylinder, to a 5.0 V8...so i need these tips too. *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch*
KiKaZz74 Posted January 30, 2014 Author Report Posted January 30, 2014 I use 4x4 sometimes so ill keep shaft. :/ seafoam I do on a longer trip and these next times im gonna do 93 vpower with it See what I get mpg wise. Ive head to much bad about royal purple so im staying away. Ill probably start running high mileage in it. And ive been bad at not driving agressive lately. But it honestly doesnt seem to hurt my mpg. I cant tell tho cuz ive been getting 30-50 miles less per tank due to all the idling and warming up ive been having to do My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
alaskanzx5 Posted January 30, 2014 Report Posted January 30, 2014 save money and buy a daily, maybe even an auction. get a little commuter. I had an escort manual tranny got up to about 38-40mpg at one point. had over 150k miles on it but the head was rebuilt. paid 300 for it and it came with the stuff to replace/rebuild the head (it was warped). if voltage drop is bad during driving turn the volume down. less voltage going to the engine means weaker spark. if its real bad it could affect the reading on some of the sensors but im not sure on that. k&n filters have been proven to increase mpg and so has cold air intakes. well I cant think of anything not mentioned so I not going to repeat more then I already did. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
