justin0943 Posted January 30, 2014 Report Posted January 30, 2014 like I said before take the clutch fan out and put in electric fans in, all the new trucks are like this now thats the reason they are getting 22+ miles.an also you will loose mpg when cold because of the veichal running richer but on the plus cold air=more hp also about the voltage thats true did mine and lost about 1.5mpg when playing my system which drops to 11v 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
KiKaZz74 Posted January 30, 2014 Author Report Posted January 30, 2014 ill look into a cai. the fan idk. i already have shit electrical for my system. dont they pull a decent amount of amps? how about replacing the fan with a lighter and newer one? My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
KiKaZz74 Posted January 30, 2014 Author Report Posted January 30, 2014 save money and buy a daily, maybe even an auction. get a little commuter. I had an escort manual tranny got up to about 38-40mpg at one point. had over 150k miles on it but the head was rebuilt. paid 300 for it and it came with the stuff to replace/rebuild the head (it was warped). if voltage drop is bad during driving turn the volume down. less voltage going to the engine means weaker spark. if its real bad it could affect the reading on some of the sensors but im not sure on that. k&n filters have been proven to increase mpg and so has cold air intakes. well I cant think of anything not mentioned so I not going to repeat more then I already did. ive been looking into a different daily. just use truck for towing and winters. but that will most likely have to wait until atleast spring. id want something decent that i dont have to dump money into and can drive for a while. i mean my truck looks brand new and its a 97. id wanna look around 03 and on with lowerish miles and no more than maybe $1200 My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
justin0943 Posted January 30, 2014 Report Posted January 30, 2014 ill look into a cai. the fan idk. i already have shit electrical for my system. dont they pull a decent amount of amps? how about replacing the fan with a lighter and newer one? it depends which setup and the cfm a dual fan setup will draw a bit but you can go single around 2500 cfm to 3k cfm and be alright on stock alt I'm planning on getting 2,600 cfm for my dakota with stock 90amp as for just changing the fan for a lighter its still the same the motor is still going to push air which thats the reason for the mpg difference with eletrical fan you taking stress off the motor which makes it happier. 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Crandis16 Posted January 30, 2014 Report Posted January 30, 2014 4-pin vs 2-pin injectors have been known to put out a better fuel injection pattern, resulting in better MPG My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
KiKaZz74 Posted January 30, 2014 Author Report Posted January 30, 2014 I saw on that spike episode they just replaced the fan without the shroud. Just used stock shroud. Might have to look into that. 16" fan sound good? Ive got a 136a alt but my system is roughly 2000w and it dims bad at night so I try not to hammer on it then. Injectors I wont get into. We have a mechanic but im wanted something that can be done without him and special tools. The fan and wiring crap I can do. Cai idk bout. I wanna try and get another battery up there where the filter box is if possible. But might have to go kn filter for now as the reputable cai companies seem to be well over 200. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
alaskanzx5 Posted January 30, 2014 Report Posted January 30, 2014 make a replica cai with parts from parts stores. they make diy kits/parts. I know a few people that did it on cars for less then $100. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
boom50cal Posted January 30, 2014 Report Posted January 30, 2014 On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
KiKaZz74 Posted January 30, 2014 Author Report Posted January 30, 2014 No way in hell im riding a bike around here with the weather swings lol. I do in the summer on and off tho. Could you link some of the parts to do a diy cai kit? My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
oldsoundguy Posted January 31, 2014 Report Posted January 31, 2014 I agree with slow down. My 99 toyota Tacoma ext cab 2wd 5speed gets 26 mpg hwy if I speed( 67-70) I have got a best of 32 mpg hwy by setting cruise at 60. I just don't ever get in a hurry and give myself plenty of time to get to work. I also check tire pressure every couple weeks. I put redline oil in my trans and royal purple in the rear dif. Change oil every 6000 miles. I check my mileage at every fill up. I never just put in half tank always close to empty then fill. Run seafoam before winter and then summer. All this helps. Bad front end alignment can also cause a lot of front end drag. Bad brakes or calipers dragging etc like that. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
