S10 Blow Through, 4 Mayhem's, First Video & Voltage Drop Issues :(
Working on some voltage drop issues, not sure if it is because of my lack of big 3 yet or not. Here is a video, please pardon my mess it is under construction.
www.youtube.com/watch?v=Y27ze7F6l5c
Alpine CDE-HD149BT Head Unit
Hertz HSK 165XL
Audison SR4 (Running the Hertz 6.5)
Audison SR2 (Running the Hertz Tweets)
Ascendant Audio Mayhems 4- 12" (Being Built)
DC 7.5K
230 AMP Singer ALT
6 XS-D3000 Batteries (Back) (In the works)
1-XS-D3400 Battery (Front)
Lots of SHCA Wire and Accessories.
Do your big 3. Not a good idea to upgrade the alt and not upgrade the wiring. Your alt can now put out more power than the iwres can handle and you can either melt something or pop the fusible link and or fuse.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
^^^ what he said... you definitely need to do the big 3 quick and see what changes that makes,it's bad that you're dropping like that with only mids/highs playing??
Yes no subs yet, my temp box is being built for the temp 12 that I am putting in. I hope to have my big 3 done in the next 2 weeks if work goes well. My biggest issue is I am not sure I can get to the ALT power and ground myself so I might have to pay to have it done.
Hertz HSK 165XL
DC 7.5K
230 AMP Singer ALT
honestly with a 300a alt, only stock size XS batt, and big 3, you should not be seeing anything .1 or .2 below idle voltage running just a few hundred watts.
edit: if you havent upgraded the charge lead to 1 or 2 runs of 1/0 OFC or 1 run of SHCA 2/0, do that FIRST. Maybe you have a huge choke point waiting to burn.... literally. But still a stock alt with a D3400 up front on 400-500w shouldnt lower you a full volt.
I agree fully.
I would DOUBLE CHECK, with a fluke, set at min max.... You see that drain,.. when it happened? It wasnt even at draw. My bet is its in the cig lighter..
Do it with a meter......at point of source.
I agree fully.
didnt even think of that, forgot those come with the cig lighter adapter until you clip it.
x2, put a meter into the pos and neg of the migs/highs amp and see what you get.
Let me help real quick
http://youtu.be/Y27ze7F6l5c
Thanks, hoe do you embed it?
Hertz HSK 165XL
DC 7.5K
230 AMP Singer ALT
