Anton miller is a retard
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I mean idk the guy, retard or not he has one loud trunk car.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Tore it all apart turned them around and MUCH happier! 3 weeks til I see if it helped on the meter, but it sure sounds like it will! I might even put in a second battery by then!
Several systems, several vehicles. Always changing!
2013 MECA State Champion (trunk 1)
2014 MECA State Champion (mod 4)
2014 MECA state Champion (Park and Pound 4)
2014 DBDRAG 6th place North America Finals (SS1-2)
2014 BASS RACE 6th place North America Finals (139.9)
Maybe that trunk is better off with subs facing the rear, not all trunk cars are louder forward and sealed
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
another idea for ya.....It you can, turn the box forward-facing again but shove it all the way back to the trunk lid and see how it sounds.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
this, there has to be a reason why pretty much anyone that's loud from the trunk firing into the cabin shoves their box as far back as possible into the trunk before sealing it off.
The higher notes could just be echoing off of the trunk lid in a sense. When I had a single 12 in the trunk facing forward I remember the higher notes seeming quieter than the lower notes and they never really came through as well. Granted I never tried turning the box around and firing to the rear but it might just be the case that the higher notes "echo" when rear firing
I've tried every which way now. It is just simply loudest pointing back. I did cut some vent holes in the plastic/carpet liner in the trunk. This allows the sound/pressure/air to get into the hollow structure from the trunk to the cabin. That made a difference. I also found a rubber flapper vent from the trunk to outside the car. I pulled it out and sealed it. Another small difference there. I have pulled the box out and pulled the short side of the port out. Depending on the calculator I use, I went from 28-30 to 32-34 hz. Small change but it was easy! I am also in the process of applying resin to the entire interior of the box. Oh, and a battery in the trunk! Hoping that lots of little things add up to a decent change for the better! I would at least like to get back to the 141.9 I did before!
  • Who's Online   0 Members, 0 Anonymous, 541 Guests (See full list)
