I just had my VM-1 installed in my car today. It looks great and definitely is a nice to watch as my voltage changes- lol. But here is my question when my installer put it in I told him to wire it to my rear battery distribution blocks so now when I shut off my car it stays on which is not a problem as for me being worried about it draining my batts. How will the Display hold up doing this?
So should I just have my installer tie into the remote lead of my nearest amp to the rear battery?
Yes you can have it hooked into the amp remote lead.
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
That what i did with mine... Used the same connections (power, ground, and remote) on my main amp... Also found that i was dropping WAY to low... The Cig lighter is a easy way to do a quick check but I had a totally different reading once it was moved to the amp...
Pioneer AVHX-5800BHS
Alt CES 200/270+
Dang mine was only .2-.3 volts difference from cig to amp???
Edited by jfoodstamp
Mine is Hard wired to the back battery terminal I just asked about needing a remote with it as well.
  • Who's Online   0 Members, 0 Anonymous, 3357 Guests (See full list)
