Enclosure port noise please help
vw passat
Side note,
A 3 or 6 db subsonic filter at around 35hz would assist in remiving the the noise you are hearing,
But will come at a cost,
My wife's car has a single kicker 15" at 37hz and I fitted a 3db @ 32-33hz and I can now play down to mid 20 with out bottoming out, but its not as loud of course
If you want to do a removable port
Aeros are the easiest way to go
Either
only change the length
Or block a port
The length one is easy
Just play around with box change the length in Torres until you get 1 box that is close on speck for the longer port and same on shorter port
This is ok but not the best
Run more then 1 port and block 1 or more
For example 2x6" aero ports = 56sq" of port
Giving you 17.2:1 ratio as you have now
Tuned at what ever you chose
Block 1 off so only 1 works and you have 28sq" at 8.6:1 with is very close to where you want to be for a daily with aero (9-12aq" per ft) giving you 10-20hz low in tune
This is how I would do it
And it will also allow you to
Tune it a lot higher for meter
Idd tune the box on Torres and get it to spec with only 1x6" then just change the number of ports to 2 and see what it says
If your tuned to 40hz,no matter how big the enclosure is,no matter how low your square inch of port per cubic foot you have,you will most likely have low output at 20hz with a properly tuned 40hz setup. With your subsonic filter off,or set to low it will most likely cause mechanical damage if your unloading your subwoofer like crazy below 30hz. I would take the advice and build me a new enclosure,using aero ports on removable baffles so you can make as many baffles as you want,and just slap them on for different tunes. OR just build a new box tuned to 30hz. Be aware that most music will have a significant output loss in bass unless your listening to chopped and screwed,decaf,wiz khalifa ect... You will also most likely have a lower score the lower you tune.
Port airspeed will be maximum around tuning. Maybe you should post a vid of that noise.
hi joe i scraped the box and anything below 30ish is just air flowing in and out of a tube below 36hz there is no backpressure in the box and if i make a bigger box like 4ft^3 with 14sq it sounds the same air flowing in and out even when i make another one with 4ft^3 16sq it sounds like crap this subwoofer is amazing ):
I did a quick test with some numbers, If you could fit a pair of 6", full length aero ports that may do what you want. Both open = higher tune. One plugged = lower tuning. box being between 3.5 and 4 cuft
Its not the sub its the box and tuning. You want the best of both worlds. Crushing lows and a high tune with some decent SPL. That just isnt going to happen. If you want a wider bandwith you need to shrink the port area. But even that probably wont hit a mid 20hz note with any authority tuning at 40hz. If you want to hit lows I would be tuning that sub around 32hz, using an aero port or even a square port with about 9-12sq in of port area per net cube. Now having said that you will probably be loosing some bandwith in the higher range over 40hz. But musically it will sound 1000 times better. Thats just my 2 cents.
Or do like snowdrifter said and use a 2 port setup. Or even a musical daily box and a second box for your higher tuning.
  • Who's Online   0 Members, 0 Anonymous, 565 Guests (See full list)
