kl0wn Posted July 21, 2013 Report Posted July 21, 2013 Recone time. Recones are easy though, don't be scared of them. But before you go order a recone, pull the sub out and take a good look at the motor, when you hit the hill, it could have hit just right, and caused the motor to shift. My table broke while my box was sitting on it, hit the ground and jared the subs good enough to shift 2 of the motors rendering them useless unless I bought a new motor, and recone. IF that is your case, and the motor shifted, I would just buy a new sub. 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
Nikitaaa Posted July 21, 2013 Report Posted July 21, 2013 Dang those things must have been moving for the coil to hop out of the gap. If you can manage to maybe tap the coil back into the gap somehow? But then again it's probably out of alignment now. 2007 M/T Honda Civic Coupe EX (4) Sundown Audio X-8's (2) Ampere Audio 3800.1's (3) Stinger SPV-44 Batteries (1) Mechman 240 3:1 Ratio 4th order sealed from the trunkTEAM NWSPLBest termlab scores to date in Honda trunk:151.7db legal (official) IASCA trunk 3 classBest termlab scores to date in my walled Subie:152.9db legal (unofficial) IASCA advanced 2 class155db outlaw
CHEVY4X4BLAZER Posted July 21, 2013 Report Posted July 21, 2013 If it can be blamed on box design. Make sure you tell mr 412cvx about it so his butthurt can begin again.
Trey_Dog650 Posted July 21, 2013 Report Posted July 21, 2013 The subs are skar zvx 12's I think 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
Swordlordboy1234 Posted July 21, 2013 Author Report Posted July 21, 2013 I'm gonna take the sub out and see about getting it back in the gap. Then I'm gonna figure out the box thing. How do you know this box design was from 412? My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Raptorman Posted July 21, 2013 Report Posted July 21, 2013 412 owns "Ground Pounder Customs" 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
tacomaguy1 Posted July 21, 2013 Report Posted July 21, 2013 Even if you put it back the bottom of the former is probably bent a little which will cause rubbing Team Flex Issues
SnowDrifter Posted July 21, 2013 Report Posted July 21, 2013 I'm gonna take the sub out and see about getting it back in the gap. Then I'm gonna figure out the box thing. How do you know this box design was from 412? It says ground pounder customs in the lower left. He created a facebook page after he rage quit here ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Swordlordboy1234 Posted July 21, 2013 Author Report Posted July 21, 2013 I'm gonna take the sub out and see about getting it back in the gap. Then I'm gonna figure out the box thing. How do you know this box design was from 412?It says ground pounder customs in the lower left. He created a facebook page after he rage quit here Hmmm.... Good to know... So the coil is prob bent right? Most likely.... I'm gonna try to pop it out and see how bad it sounds and see if it will work for heatwave, then I'm gonn work on a recone / subs and figure out this box thing..... Pissed ..... Really pissed right now. Dre sold me a design from 412....? The know box fuck up..? Ugh My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
