Cresendo BC3500 issue.
Amart88
Well, now that they are strapped, the master (working amp) completely shuts off when I crank it up... If I switch the master to the bad amp and slave to the good one, I get very little bass. Bass boost is turned off always. on HU and amp.
What I tried:
I Tried switching the RCA's every which way.
flipping master/slave a few times.
Strapping them. (now have new problem) ^^^
Turning gains down lower.
Voltage is constant 14.7-.9
Everything is secured.
What I'm going to still try:
Checking ohm load again
replacing amps fuse.
measuring rca sheilds? Need some more info on that.
I need some more explanation of checking the RCA's and what to look for. Also anything else to maybe try before I send this POS somewhere. I figure it's the bad amp causing the good one to somehow shut down while strapped.
Crescendo have not got back to me yet.
Swap your woofers around what was on amp one kove to amp two see if the problem follows.
Test each woofer alone
Try swapping your rcas and jumper from the other amp. I dont like jumpering id prefer the y adapters
Maybe swap rcas if possible
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Same head unit as your car too?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yep, Kenwood KDC-345u I believe.
I switched the woofers and the problem follows the amp. Also swapped the RCA's when they were separate. The problem still continued. Even running just the "suspect" amp it put out jack all for output. Even lower output voltage.
No way to borrow an amp to rule out hu or rca's?
No. Sadly, nobody remotely close o me runs this type of gear. I wish I could though. I don;t think it's RCA's as I have ran the amp by itself with no luck and the other works fine on the same ones. I am going to go out and measure the rca voltage right now. Just weird that the working one shuts off now.
First thing I would do is swap ina new head unit. even if you "borrow" one from a best buy or whatever you call it up there.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Sounds like a nightmare. I would go buy a headunit and hook up everything outside the car with a battery. Rule out RCA's and headunit. Return everything when done troubleshooting.
Google it
  • Who's Online   0 Members, 0 Anonymous, 4622 Guests (See full list)
