Lanzar Opti 7001
jizazz12
Was thinking about using this amp, the spec's on it seem legit does anyone have any experience with them? Do they do rated power?
I haven't heard anything bad on the lanzar Optidrives so looking for some incite.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
  • 1 year later...
Opti line and Max line are very different animals, but yes, the max line is horrible horrible crap that lanzar should be ashamed of.
Hammerdown... 1%
What stevil said.
The optidrive line from lanzar is the only line worth a damn when it comes to their amps.
That series subs from lanzar is just boasted crap, chincy 3inch 2layer coils with single soft spider setups claiming 2000wrms.
I have not seen 1 tested but I just purchased 1 after doing much research and fafter hearing some reviews from people smarter than myself heh. They said its a Korean board like many of the quality amps being used today. Physically it is a beast, is massive next to my planet audio BB2400.1 which probably does 2k ish RMS. Check out this video,
title says 7000D but they dont make a 7000, its a 7001. People will always trash talk certain companies even with no first hand experience, and to be honest I would expect it more from a company which as Lanzar because they do make some very entry level equipment. From what I've read the Optidrive amps are solid.
01 Chevy Silverado X-cab
2 Sundown Z18v4 walled on 2 Lanzar Opti 7k's strapped at 1/2ohm = each amp wired to 1/4ohm. Havent checked impedence rise so not sure what they are actually seeing. 6 group 31AGM's.
2-Eclipse 34230's each one running 2 Eminence 6.5" Beta 6A. These are beastly mids rated at 350w program power. I was skeptical but the eclipse amps are 370w x 2 and when there was 4 mids on 1 amp I could push it into thermal protect within a song so added the 2nd amp.
Eclipse 4212 running 4 CT sounds Meso tweeters. and 2 DLS ultimate tweeters up high to raise the soundstage.
96' Ford F350 4wd 4d long bed 7.3 diesel with 91k miles. Will be the sound quality rig if I can ever find the time.
  • Who's Online   1 Member, 0 Anonymous, 738 Guests (See full list)
