DC Sound Lab
yes
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
Just double glue it and maybe carpet it at some point. should be fine.
i made a PA Sub out of particle board. that was fun hahaha but its still holding up great.
Edited by DJ_Stubbs
2007 Dodge Caliber SXT 2.0L
Flowmaster Single muffler + Tip
4 SoundQubed 6x9s 3-way
PolkAudio PA660.4
2 MB Quart Tweeters
2 4" MB Quart 2-way
New 8" coming soon!
I don't understand what this question has to do with DC Sound Lab, but it should be fine. I wouldn't put it in the middle of the panel though, probably closer to the edges where it's a big stronger
Whoa particle board?.ive used it to mount cabin speakers but I stay away from it to make sub boxes...to me its too weak and too porous...not very good resonance..the reason why I ask if I need to double it is because I had a 4.8 cu ft box that was 1.5 inch thick and I had a 12" memphis mojo in it..come to find out it was the 4 ohm version so it was wired to two ohms. Guess I was only pushing 750w outta my 1 ohm stable 1500w amp ..and guess what the damn sub tore that box up afte 4 yrs..mojononly wieghs about 40lbs but tbis 15" t2 sub wieghs about 65lbs..and its the 2ohm version so ill be pushing the full 1500w rms..I just dnt want to have to rebuild this box..hahaha
You need trunk space to get groceries and shit...bitches love groceries
My t2 15 only weighed 53, I had it in 2 boxes over the time I had it, both without bracing and only a single baffle all the way around. You should be fine, but if its worrying you it cant hurt to do wooden dowels for bracing
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
  • Who's Online   0 Members, 0 Anonymous, 597 Guests (See full list)
