Need help with final tuning, having issues...
Karkov
check all fuses
maybe wires for pinched areas, worn areas, and bare
try checking ground and or redo the ground could be corrosion/dirt and make sure no paint is under it some people think they can "get away with it"
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
Tried those things, been fucking with this thing for nearly 12 hours now. About to give up. Have no extra HU and amp to try but hardly matters since I have 3 amps and multiple runs of RCA's i've already plugged all into each other to try and narrow it down.....
Ground loop isolator ? New head unit?
Edit;
Thanks though guys
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Try hooking an iphone or something similar to it. There's a headphone jack to rca cable you can use. First hook it up at the rca's behind the radio. If the issue is still there, it isn't the radio. But you need to take it completely out of the loop. Disconnect all rca's from the radio. (make sure you tape them so they don't ground out on anything) Then hook it up closer to the amps. Eliminate possibilities. You will have to jump the remote to power the amps up. I would start at my radio and work back to the amps. If you isolate everything and you still have problems at the amp, you will know where to look.
2002 GMC 2500HD w/8.1 liter v-8
Pioneer Avic N-5 HU
Pioneer CD-BTB200 Bluetooth
Pioneer CD-UB100 usb
Pioneer GEX-P910XM XM receiver
Pioneer CD-1200 IPhone adapter
Pioneer TS-W309D2 subs x2
Audiopipe split 3003
2 Autotek 3-way active crossovers
2 alpine tweeters
RF Punch P132 3.5" full range
RF Power T1462 4x6 full range
RF Power T1693 6x9 3 way
RF Power T2652 T2 6.5 components
2 Autotek ATX 1200.4 amps 4
RF P400 amp
Massive N4 nano-block
I measure loud by the amount of smoke it puts out.
www.enforcer-gaming.com
Ordered new HU all together, got something more mainstream, was a little iffy with the performance of the one I had. Pretty sure that is my problem with this whole thing after checking and isolating about everything else.
RCA's not pinched, all connections tight, swapped around all amps on different speakers and RCA's on all their settings, removed amps, checked all wires, shortened wires, re-installed amps, kept wires separate, checked ohms of subs through dmm or whatever, sound was still there whether DVD, CD, USB, FM, etc. etc.
I think the only piece of equipment left is the head unit. Even changed up the amps wiring to batts and eliminated 1 batt and some other misc. options. Getting feedback in ALL speakers no matter what. With DD-1 gain on amp all the way up without distortion reading for a 5v pre-out deck?
Fuck it, want this thing working properly. If HU doesn't fix it i will have RF gear for sale next week.
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Sorry I looked through your build awhile ago, but what head unit are u running
2003 GMC Yukon Denali
Alpine CDA 117
Redoing Mids/Highs
4 Runs of 1/0 Knukonceptz 2+, 2-
4 Deka 9A31's in back (Stock underhood) 250 amp Alt.
AQ20K
2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
currently Eclipse AVN726E until my new one arrives. I think highly of Eclispe but i gotta fix these issues some how or another, lol
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
This thread can be closed
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Did you figure it out yet? I can assure you it's not your RF gear,there's no way all those RF amps have issues like that. Just doesn't happen.
Nah, took everything out (minus the RCA's under carpet), including electrical under hood, haha. When I get new head unit I will re-install things and try to eliminate EVERY possibility of issues, thought i did that the first time but meh, guess not. Might take this opportunity to paint box a little darker also.
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
