01B4000 Posted August 22, 2013 Report Posted August 22, 2013 Trying not to start a VS thread but I'm stuck here. I'm doing a budget build for my Mazda B4000 and I want to know which will be a better and louder choice. EVERY DOLLAR COUNTS 2 Soundqubed SDC 2.5 15s or 4 MB Quart ONX304 12s Running on 1400-1600 watts Opinions? Are there any other better options? 1 Kicker 10CVX124 12 inch woofer Oldschool 2 Channel 400 watt rms Kenwood Pionner DEH7500 Headunit Pair of Alpine Type R 6x8 on headunit power Termlab- 138.0 sealed 139.2 db w/ windows down Redneck build : http://www.stevemeadedesigns.com/board/topic/171829-redneck-stereo-in-mazda-b4000-repost/ NEXT SYSTEM- 2 Soundqubed SDC 2.5 15s" Cadence 2500.1 Amplifier (1200 watts) 4 6.5s Cadence fiberglassed in doors (Not sure which brand to go to) 4 1" tweeters in front pillars 2 6.5s Cadence in rear pillars 2 Cadence 800.4s
01B4000 Posted August 22, 2013 Author Report Posted August 22, 2013 Help? 1 Kicker 10CVX124 12 inch woofer Oldschool 2 Channel 400 watt rms Kenwood Pionner DEH7500 Headunit Pair of Alpine Type R 6x8 on headunit power Termlab- 138.0 sealed 139.2 db w/ windows down Redneck build : http://www.stevemeadedesigns.com/board/topic/171829-redneck-stereo-in-mazda-b4000-repost/ NEXT SYSTEM- 2 Soundqubed SDC 2.5 15s" Cadence 2500.1 Amplifier (1200 watts) 4 6.5s Cadence fiberglassed in doors (Not sure which brand to go to) 4 1" tweeters in front pillars 2 6.5s Cadence in rear pillars 2 Cadence 800.4s
JesseyMclame Posted August 22, 2013 Report Posted August 22, 2013 You'll probably be happer with the 2 15s. Better quality, better sound, overall better speaker. Current setup in my 96 Hoe Hu - Pioneer DEH-80prs. Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets) Batts - 4 91ah rear batts, 50ah batt up front. Subs - 2 Crossfire XSv2 18's Alt - Singer 330A Front stage - Random JL & Eclipse mids, Eclipse tweets
john253a Posted August 23, 2013 Report Posted August 23, 2013 Ib4tl Why them Why not list everything you have now And how much you want to spend on the upgrade and some people will chim in with suggestions If money's is tight less and bigger is the way to go In your car if you don't mind walling it 2x 18" will give you the biggest bang for buck But to stay at window line stick with 15's or a single 18"
jarrius Posted August 24, 2013 Report Posted August 24, 2013 I would go with the 2 15's unless you want to wall it then I would go with 4 soundqubed sdc2.5 12's but that's just me 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
bkolfo4 Posted August 24, 2013 Report Posted August 24, 2013 Get all the answers you can before the thread is locked! Why will it be locked? Because there is no good answer. And maybe there are better answers you have not listed. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Joe X Posted August 24, 2013 Report Posted August 24, 2013 The MB Quart ONX304s are dual 4 ohm, so you can't wire 4 of them to one ohm, which is the minimum stable impedance of most medium power cheap amps, for that reason alone I would pick the 2.5s.
