XS Power
Your battery bank depends on what your Alternators charging capability is. If you have a 200a alt, figure the car is going to require about 50-65a of that and leave the rest for the audio. So now you have 135a of charging capability from that alt and the rest has to be made up by the batteries. With the bc5500 and t-600, you are going to have the possibility of drawing 6-700a of current, not saying that is exactly what they are going to draw, but they could. I always plan for the worst case scenario when planning electrical systems.
The following is by no means the only way to calculate how many batteries you need, but has worked pretty well for me so far.
700a of current draw
- 135 amp of alt output
=565a battery support
D3100- 110ah
565/110=5.13
My recommendation is 5 XS Power D3100s in the rear along with whatever size XS battery is a direct drop in under the hood.
Hope this helps.
  • Like (+1 Rep) 4
D3100- 110ah
565/110=5.13
Hope this helps.
O_O...5?....Sheeeeeeeeitttttt@@@!!
I have 30 XS 14v batteries just for my 14v side along with 1 D6500 and 3 D3100s for my 12v side. Your electrical system is the backbone of your build, if it is weak, then your system wont perform to its potential.
holy fuuuuuuuuuuuuuuuuuck man....truly insane. Now i feel like my build sucks, haha! cool shit bro love it, dedicated for sure
  • Like (+1 Rep) 2
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
I had 4 3100's and 1 3400 off a 300 amp dc power spx alt and voltage didnt go below 13. 2 crescendo 3500's at 1 ohm
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
I can only use a 200 amp alt, so i'll have to add another bat or two of what you have.
Is 200 amp the biggest plug and play alt, or biggest alt period?
You asked Singer about a bigger option that may bolt on, even with some metal fabrication, and external regulation?
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
I have not, metal fabrication would not be a single problem for me, I'm a welder/fabricator, And I ment plug and play.
Yeah, ask Mike, if he can offer a 300 amp alt that can fit in the Accord, you won't need to have so many batteries, and being a fabricator is a good advantage.
2003 Kia Sorento
Team Subsonic Lows
I run 7k with 4 d3100's and I still drop pretty low.
How low?
I'm running four D3100's in back, D3400 up front a Mechman elite 370, powering an NS1 @.65 and I stay in the highs 13s full tilt. Lowest I've seen is 13.4ish.
