New to building boxes, going to be building a box for 4 ,6x8 speakers for shop system. Planning on fiberglassing the inside corners of box to strengthen it a bit, but I have never worked with fiberglass before, and my really sure what to use. Box will be made of 3/4" MDF and was also wondering if anybody had any insight as to how big I should make the box for 4, 6x8 powerbass 2xl speakers, thanks
i dont think you need reinforcement for door speakers.... i have a speaker tower me and my friend made with 4 rockford 6x8s and 2 rockford 6x9s and it doesnt flex at all or anything
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
You dont need to brace it at all or even fiberglass it
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Mainly wantin to glass it because the corners will all be squared off and screws and glue won't be the best method to hold them together even though I will be doing that
Why would wood glue not be good for the corners? I used tight bond 2 and finishing nails for my box and it holds together fine. Glue should be good
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Glue won't be the best method to holding the box together? What are you talking about Willis
dude mine isnt even glued lol i think youre over thinking this
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
A hand full of screw
Some wood glue
And silicon
Glue and screw the box together
Cut out your holes
Silicon the edges through the speaker holes
Bam
Speaker tower made
Now if you want to do a bit more then the normal sealed tower
You have approx 150sq" of cone area
Close to the same as 2x 10" or a bit less then 1x 15"
So you could build the box between 2-3cuft net porter at around 40
You dont need any reinforcing for those. It's not like it will break anything but it's a waste of material. In all honesty you could build a box out of particle board and hot glue for them and it will be strong enough lol
  • Who's Online   0 Members, 0 Anonymous, 579 Guests (See full list)
